Print at Oct 1, 2026, 9:18:05 PM
Posted by whippetsleek at Sep 27, 2010, 10:39:55 PM
Java Question
This is not a Sweet Home issue, but I am hoping someone knows the answer. I have just finished an installation of Xubuntu on a laptop computer, and I'm trying to get Sweet Home to run, but it tells me that it can not find the jre6.bin? I have downloaded the files directly from Sun Java, and I know their path, I typed it in correctly, and changed it's permission. The bin file will start to unpack, but about two minutes into unpacking, it will say it can not find jre.bin. The file size was the same so I don't think it was corrupted, but I redownloaded the files just in case, and I still get the same error. I have just started learning the different commands in Linux, so am I doing something wrong? Should there be another step after you change the bin file permissions?
Sorry if this is a newbie type question, but I am one... smile
Posted by hansmex at Sep 27, 2010, 11:08:42 PM
Re: Java Question
Chris,
If you want to install Java on a (x)Ubuntu machine, you can (should?) do so by choosing Applications --> Ubuntu Software Center . There you can search for Java, and install it correctly with one click.
If you need more help, you may want to try www.ubuntuforums.org, where you can find help on any topic you can imagine, or else search using Google.
Posted by whippetsleek at Sep 27, 2010, 11:35:00 PM
Re: Java Question
The Ubuntu Software Center has the jre 5, I was hoping to get the new jre 6. I can only find that at the Java website. I am also trying to install manually so that I know how to do it the next time in case I can't go thru the package installer. The instructions I recieved from the Ubuntu help forums were the same as what is on the Java site, on running as super user, changing permissions, and such. I have everything up to the actual unpacking of the software done, I was just hoping someone here might have had the same problem, and found a solution. I will likely just go ahead and download jre 5 and update it afterward if I can't find a solution
