Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Control of virtual visitor |
| Print at Oct 3, 2026, 10:53:45 PM | |
| Posted by hansmex at Oct 16, 2010, 11:25:40 AM |
Control of virtual visitor Emmanuel, Would it be possible to add two controls to the virtual visitor? 1 - Inclination, in degrees, to exactly control the up-down movement of the "head" 2 - Orientation, in degrees, to exactly control the left-right movement of the "head", where zero degrees is exactly North or "up" Ideally these would be added twice: 1 - to the 3D view --> Modify menu , directly underneath the existing two controls 2 - as a right-click pop-up menu from the virtual visitor, together with the two existing controls Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Mar 9, 2012, 10:28:00 PM |
Re: Control of virtual visitor All the attributes of the virtual visitor can be edited with the new dialog box shown by 3D view > Modify virtual visitor menu item available from version 3.5. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Mar 9, 2012, 11:34:06 PM |
Re: Control of virtual visitor Emmanuel, Thank you, I already tried out the new feature and it works GREAT!! Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Mar 10, 2012, 12:08:11 PM |
Re: Control of virtual visitor Thank you for your feedback ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 10:53:45 PM |
