Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Who can make a triangle for me? |
| Print at Sep 30, 2026, 9:59:53 AM |
| Posted by hansmex at Nov 9, 2010, 9:39:20 PM |
Who can make a triangle for me? Hello all, It's easier for me to answer a 100 questions on this forum, than make one simple, although special, triangle. I spent several hours with Art of Illusion and Misfit 3D, but without success. So, who can help me? What I need is a "triangle" that fits in the corner of the model in the image. Basically the top horizontal line of the white triangle should be merged with the bottom horizontal line. The resulting model has three equal faces measuring 1.00 x 1.00 x 1.414 cms/units (and corners of 90, 45 and 45 degrees), and a diagonal face measuring 1.414 x 1.414 x 1.414 cms/units (and three corners of 60 degrees). The 1.414 is of course an approximation of the square root of 2. Thank you VERY MUCH in advance. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Nov 9, 2010, 9:51:03 PM |
Re: Who can make a triangle forme? Did you try this? - import the triangle, - make it thin, - rotate it by 45°, - export it to OBJ format, - reimport it and change its orientation in the second step of the import wizard. It might work... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 9, 2010, 9:55:38 PM |
Re: Who can make a triangle forme? Emmanuel, Maybe I should call it a special tetraeder? Not one with 4 equal sides, but one as described. I already have the "original" triangle imported in every possible orientation, because I use it as one of my basic building blocks. I would also be happy with a model that looks like a quarter of a cone, because that would also fit in the corner of the model in the image. (or even better: both) Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by whippetsleek at Nov 9, 2010, 10:02:07 PM |
Re: Who can make a triangle forme? Hansmex, Have you tried exporting the entire model, and then importing into Blender, export as DAE, and then making the triangle you need in Sketch? ---------------------------------------- ![]() |
| Posted by hansmex at Nov 9, 2010, 10:09:52 PM |
Re: Who can make a triangle forme? Chris, Apparently my 3D skills are below par, and I don't have the patience to sit down and learn these programs. I've never mastered SketchUp, less Blender, nor Art of Illusion or Misfit 3D. There's a good reason why I use SH3D to build my furniture... Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by whippetsleek at Nov 9, 2010, 11:55:30 PM |
Re: Who can make a triangle forme? If you can attach or upload the sh3d file of the entire model you have there, I'll try and see if I can make the triangle ![]() ---------------------------------------- ![]() |
| Posted by hansmex at Nov 10, 2010, 12:10:07 AM |
Re: Who can make a triangle forme? Like this?? ![]() ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by whippetsleek at Nov 10, 2010, 11:38:59 AM |
Re: Who can make a triangle forme? Did you already make it? Or is that just what you want? That looks like a roof. ![]() ---------------------------------------- ![]() |
| Posted by Puybaret at Nov 10, 2010, 9:07:05 PM |
Re: Who can make a triangle forme? Hans, here is the triangle corner you requested. Copy paste the following lines in a obj file and import it in Sweet Home 3D: g corner---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 11, 2010, 12:32:30 AM |
Re: Who can make a triangle forme? Emmanuel, Thank you very, very much! This is exactly what I was looking for! Hans ![]() ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 30, 2026, 9:59:53 AM |
