Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Console renderer |
| Print at Oct 3, 2026, 6:39:23 PM | |
| Posted by chipmaster at Nov 19, 2010, 10:50:23 PM |
Console rendererEmmanuel, Thank you for this project! I'd like to have a console application without DirectX/OpenGL requirements. Unfortunately, virtual instances in the clouds doesn't have real video card. I can use my own computer with video card to create plan, and then order virtual instance in clouds for rendering foto/video as fast as I need. Ideally, it should be flexible: process one file on many instances simultaneously and use load balancer to reduce time... ![]() |
| Posted by Puybaret at Nov 20, 2010, 12:22:33 AM |
Re: Console renderer The rendering at the two best quality don't need any graphic card to run. But the program itself requires DirectX/OpenGL support to run if unchanged. I could try to create a special version that will be able to run in batch mode without DirectX/OpenGL support. It will simply compute a picture from the last saved parameters in a SH3D file, with some feedback in the console. If you're interested by this, please fill a feature request. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 6:39:23 PM |
