Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: bug in time setting? |
| Print at Oct 2, 2026, 10:32:31 AM | |
| Posted by hansmex at Dec 1, 2010, 12:01:48 PM |
bug in time setting? Emmanuel, Maybe there is a small bug in the time setting of the rendering dialogue. When I click up and down, the time changes in steps of 1 hour. When I try to set a specific time, say 08:45 AM, things become difficult. When I delete the entire time and start typing 08:4, the cursor jumps forward and I get something like 08:4A5M. Probably it's a bug that's there before v3.0, but as I rarely use other setting than 12:00 I've never noticed it before. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Dec 1, 2010, 12:29:52 PM |
Re: bug in time setting? The best thing would be to replace the date and time fields by something a little more... easy to handle like a calendar and a clock. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Dec 1, 2010, 2:23:14 PM |
Re: bug in time setting? Emmanuel, Maybe this is a stupid answer.... Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by hansmex at Dec 2, 2010, 2:40:41 PM |
Re: bug in time setting? Emmanuel, Exactly the same bug as described in the first post of this thread is happening in the Edit Furniture window. I'm not quite sure yet if I can reproduce it on command, but I think I can give a hint. It happens when you enter a value like .123, and it doesn't happen when you enter 0.123. Also, The model section W-D-H seems to be affected only. The X-Y-elevation part doesn't show this problem. I'll keep an eye open to see what-when-where. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by minaaaa at Aug 7, 2025, 4:13:44 PM |
Re: bug in time setting? i got exactly the same one |
| Posted by Keet at Aug 7, 2025, 5:45:47 PM |
Re: bug in time setting? With the current version (7.5) I see no problem with this. When you enter the time field the up/down keys change the hour. A single right arrow key switches to the minutes and you can change these with up/down. If you have a time with AM/PM then another arrow right switches to the AM/PM part and you can change it with up/down. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 10:32:31 AM |
