Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: how to drop the elevation of a room |
| Print at Sep 30, 2026, 4:09:15 AM | |
| Posted by Georgeinnj at Dec 5, 2010, 1:44:21 AM |
how to drop the elevation of a room Hi, I just started using SW3D a couple of days ago and have put together the first floor plan of our house by drawing the outer perimeter and then putting in the interior walls. One of the rooms is a step down from the other rooms but I can't find any option to change the level of that room. Do I have to recreate the house plan by using the create room method in order to change the elevation of that one room? Regards George |
| Posted by Puybaret at Dec 5, 2010, 12:52:20 PM |
Re: how to drop the elevation of a room If you didn't find the option to change floor elevation, it's because it doesn't exist. ![]() The only workaround is to place boxes at floor level that will simulate the elevation of the step. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Georgeinnj at Dec 5, 2010, 2:18:21 PM |
Re: how to drop the elevation of a room ok, sounds like it's back to the drawing board. So, I would have to go back in and raise the elevation of all the other rooms by drawing a box in each room that fills the entire floor, and also raise the height of the wall so that each of those rooms are still 8 ft high. Is that correct? |
| Posted by hansmex at Dec 5, 2010, 4:07:16 PM |
Re: how to drop the elevation of a room George, The easiest way to create a multi-level house, is to install and use the CopyAsNewFurniture plug-in. See the tutorial. Draw each floor separately, then use Tools --> CopyAsNewFurniture to copy an entire floor and stack it on top of another floor. There is a tutorial on how to build multi-level houses, but it's a bit outdated. I just finished revising it, but it hasn't been published yet. Send me your email address and I will send you the revised tutorial. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Georgeinnj at Dec 5, 2010, 4:57:43 PM |
Re: how to drop the elevation of a room Thanks, for pointing me at that plug in. I appreciate the help. Please send the revised tutorial to [email protected] |
| Posted by boymoreubon at Jan 7, 2011, 12:22:59 PM |
Re: how to drop the elevation of a room If you didn't find the option to change floor elevation, it's because it doesn't exist. ![]() The only workaround is to place boxes at floor level that will simulate the elevation of the step. Great ! you did the way I'm Thinking, I'll do this Thanks out loud. ![]() |
Current timezone is GMT Sep 30, 2026, 4:09:15 AM |
