Print at Sep 30, 2026, 4:06:45 AM
Posted by Edrd at Dec 18, 2010, 1:42:47 AM
Door opening
How do I flip the way a door opens from outside a room to inside?
Posted by hansmex at Dec 18, 2010, 6:36:04 AM
Re: Door opening
Ed,
First, go to File --> Preferences and make sure Magnetism is checked.
Second, drag a door or window on the wall where you want to insert it.
Now, while on the wall, gently move it back and forth a little bit. You'll see that your door/window can snap into place in two ways, attached to the inside or outside of the wall.
Lastly, if the hinged side is on the right, but should be on the left, do a right-click and select Modify furniture and check the box Mirrored shape.
Posted by Edrd at Dec 19, 2010, 12:04:54 AM
Re: Door opening
Yes, that works. Thank you.
Posted by nikov at Jun 11, 2011, 6:18:45 PM
Re: Door opening
Yes and thanks you from a new user...love this software!!!
Posted by guirojas at Sep 6, 2011, 4:52:10 PM
Re: Door opening
Thanks, it works great.
