Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: mass import of objects? |
| Print at Sep 27, 2026, 4:24:55 PM | |
| Posted by SilentStrider at Dec 18, 2010, 3:55:04 PM |
mass import of objects? a lot of questions I have today My question is, if I can like mass import objects into the library. Like for example when I download several (if not all) objects from archibit, do I really need to import every object individually? Haven't found something with import with the search so I think it's the right place here to ask :) |
| Posted by hansmex at Dec 18, 2010, 4:09:46 PM |
Re: mass import of objects? Strider, No, you don't. Yes, you do. Download the plug-in tutorial and read the chapter on Library Editor. You still have to import your models one-by-one, but after that you can import the entire library in one go. Another advantage is that you can easily change computers by taking with you that library. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by wrosun at Dec 18, 2010, 4:13:40 PM |
Re: mass import of objects? yup you need to import one by one or just download the contributions from many users like the files that are in .sh3f format... |
| Posted by Puybaret at Dec 18, 2010, 5:00:25 PM |
Re: mass import of objects? You can import many files at once in Furniture Library Editor. Just select more than one file in the file dialog, or drag and drop all the files you want to import in the editor window. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by SilentStrider at Dec 18, 2010, 5:20:05 PM |
Re: mass import of objects? thank you all for your answers :) |
Current timezone is GMT Sep 27, 2026, 4:24:55 PM |
