Print at Sep 27, 2026, 3:38:46 AM
Posts: 30   Pages: 3   [ 1 2 3 | Next Page ]
Posted by mitamita at Dec 31, 2010, 1:34:47 PM
Door swing in plan
does someone know how to get the door swing shown in base plan when using imported doors?
For "door swing" I mean the arch which shows the space in the plan for opening a door .
If I use the default door no problem, but with imported door (included the ones in the 3d models on this website)I can't get it.
When imported the door, of course I selected the "door and window" flag.
Thanks
Posted by hansmex at Dec 31, 2010, 2:09:23 PM
Re: Door swing in plan
Mita,
Unless you know how to program OBJ files, there's no way to add the doorswing to an imported door. However, there's an easy workaround.
Insert a hatch into your wall, then insert the door into the opening of the hatch. Rotate it 45 degrees or so, and you have a custom open door.
Posted by Puybaret at Dec 31, 2010, 2:31:48 PM
Mita, Hans,
There's no way to specify a door swing in OBJ format. The OBJ format isn't that clever! wink
If you want to achieve that with your own model, you should create a custom SH3F file containing your door model (use Furniture Library Editor if you want to), and add the following properties in the PluginFurnitureCatalog.properties file contained in the SH3F zipped file (where n is the number of the model):
doorOrWindow#n=true
doorOrWindowWallThickness#n=
doorOrWindowWallDistance#n=
doorOrWindowSashXAxis#n=
doorOrWindowSashYAxis#n=
doorOrWindowSashWidth#n=
doorOrWindowSashStartAngle#n=
doorOrWindowSashEndAngle#n=
By example, the default door defined in Sweet Home 3D catalog is defined this way:
name#19=Door
category#19=Doors and windows
icon#19=/com/eteks/sweethome3d/io/resources/door.png
model#19=/com/eteks/sweethome3d/io/resources/door.obj
width#19=91.5
depth#19=14.5
height#19=208.5
movable#19=false
doorOrWindow#19=true
doorOrWindowWallThickness#19=7.5
doorOrWindowWallDistance#19=1
doorOrWindowSashXAxis#19=5
doorOrWindowSashYAxis#19=8.5
doorOrWindowSashWidth#19=81.5
doorOrWindowSashStartAngle#19=0
doorOrWindowSashEndAngle#19=-90
I guess it's not so easy to handle but it's the way all doors and windows are defined in Sweet Home 3D. I'll try to add some options about doors in a future version of the Furniture Library Editor.
Finally, if you just want to show the swing of doors and windows defined in the 3D models page, please consider downloading the SH3F files that contain all of them with correct definition.
Posted by mitamita at Jan 1, 2011, 1:56:55 PM
Thanks both of you. You're always fast and precise!
I'll try to follow your suggestion and use the Furniture Library Editor first.
Many thanks
Mita
Posted by connomar at Mar 18, 2013, 1:58:23 AM
Please could you explain how the parameters above relate to the way the outlines work?
i.e. What is the WallDistance?
Does SashXAxis have meaning for a door?
My experiment ended up with a door that was much wider than the wall I put it in. Any help would be greatly appreciated.
Posted by Puybaret at Mar 18, 2013, 9:19:52 AM
Please, use the following figure to help you understand the meaning of the properties.
Posted by connomar at Mar 18, 2013, 1:35:56 PM
Many thanks Emmanuel, that's just what I needed.
Posted by hal9000 at Jun 29, 2013, 12:56:41 AM
So the "depth" shown on the figure is not included in the properties?
If a long walk every day were healthy, mailmen would be immortal. tongue
Posted by Puybaret at Jun 30, 2013, 2:59:16 PM
depth is one of the mandatory properties.
Posted by hal9000 at Jun 30, 2013, 3:30:11 PM
Oh, I see. I was only thinking of the properties listed above.
