Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem with textures |
| Print at Oct 6, 2026, 1:19:39 PM | |
| Posted by Poizonus at Jan 12, 2011, 2:48:17 AM |
Problem with texturesI have a problem I had designed the plan of a house in Sweet Home, a few days ago. The walls were already with their respective textures and colors, objects added. He had everything ready. And I kept And the next day as he opened the plane and everything was normal. Until two days ago, I opened everything was flat and without texture. The walls were without texture and color the objects added gris.y came out in squares and a red X. What is this? If you do not change anything. |
| Posted by Puybaret at Jan 12, 2011, 11:42:01 AM |
Re: Problem with textures What version do you use? Did you transfer your file by email or a USB key? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 1:19:39 PM |
