Print at Oct 5, 2026, 6:51:58 AM
Posted by mjlewis123 at Jan 16, 2011, 3:36:51 PM
Using the online version of the program.
I have downloaded loaded sweet home 3d but i have now found out that i am unable to save my work. Is there a way of copying this work in to the online version of the program in order to save what i have already done.
Posted by hansmex at Jan 16, 2011, 3:49:27 PM
Re: Using the online version of the program.
Mathew,
Can you be a bit more specific.
- Which operating system do you have?
- Which version of SH3D did you download? 3.0?
- Do you get an error message?
- Did you try to install SH3D again?
And, no, you can't copy from the installed version to the online version. I just tried it.
You can, however, copy between two installed versions. So maybe you can install SH3D again and check if you can save with the new program.
You could try to use 3D view --> Export to OBJ format, but note that this saves the entire design as a model, so you can't change it anymore afterwards.
Posted by mjlewis123 at Jan 16, 2011, 4:04:15 PM
Hi Hans,
My operating system is windows vista and i am running on java 6.1.
When i click the save button nothing happens, there is no error message or even an attempt to save.
I downloaded version 3.0.
I will try installing SH3D again as i am also unable to export to OBJ.
Mathew.
Posted by Puybaret at Jan 16, 2011, 5:02:26 PM
Wouldn't the FAQ Sweet Home 3D hangs when I try to save my home. How can I fix this? answer your question?
Posted by mjlewis123 at Jan 17, 2011, 5:38:01 PM
This answer does not work as the execute dialogue box no longer works with the most recent update of java 5 and you can no longer download the older versions.
