Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Join walls accurately 90° end to end |
| Print at Oct 4, 2026, 12:52:44 AM | |
| Posted by geoff3 at Jan 18, 2011, 6:31:38 PM |
Join walls accurately 90° end to end Hi, must have missed something, how do I join two walls at 90° without having to zoom in and ajust them. Is there a snap to the end center point? if you get my meaning? thanks |
| Posted by hansmex at Jan 18, 2011, 7:21:45 PM |
Re: Join walls accurately 90° end to end Geoff, Read this manual, then install the AdvancedEdit plug-in. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by geoff3 at Jan 18, 2011, 8:26:21 PM |
Re: Join walls accurately 90° end to end Hi Hans, Your link just gives me a blank page Where do I find the AdvancedEdit plugin |
| Posted by hansmex at Jan 18, 2011, 8:35:54 PM |
Re: Join walls accurately 90° end to end Geoff, Hover your mouse over the link, and you'll see it points to a PDF, which has been downloaded to your computer.... Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Jan 19, 2011, 8:37:44 AM |
Re: Join walls accurately 90° end to end To join accurately the last wall to the first wall you draw, double click on the start point or the end point of the first wall (the wall you'll be joined to is highlighted). The start point or the end point of the wall you click on is also join to the first wall you create (even if it should be highlighted... too). If ever you didn't succeed, delete the wrong wall and click / double-click again. I don't really understand why some users prefer a join operation than this simple operation. By the way, the double-click that ends a group of new walls join can be done also with the keyboard by pressing twice the enter key fast (I agree this behavior isn't so handy). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by geoff3 at Jan 20, 2011, 5:50:51 PM |
Re: Join walls accurately 90° end to end Thanks for all your help, The plugin AdvancedEdit did the trick |
| Posted by peng1 at Mar 22, 2012, 12:18:48 PM |
Re: Join walls accurately 90° end to end Does the AdvancedEditing plugin still work? I have SH3D V3.4 installed on Windows7 and I have installed this plugin V1.2 but I do not see 'Connect Walls' under the 'Plan' menu. |
Current timezone is GMT Oct 4, 2026, 12:52:44 AM |
