Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Wall is missing in 3D |
| Print at Oct 3, 2026, 10:51:13 PM | |
| Posted by KandW at Jan 23, 2011, 3:56:56 PM |
Wall is missing in 3D Hello to all, it's the first time I am using this excellent SH3D 3.0 program. I have drawn the ground plan and then the surrounding-, and inner walls. In the 2D-view everything looks perfect. But in the 3D-view one wall in the middle of the ground plan is missing. I removed this wall and reconstructed it new. But again: in 3D this wall is missing. If someone has a solution, please try to explain it in 'simple words' because I feel my English is not so good. (I am 70 years old and have no practise). Thank you in advance. |
| Posted by Puybaret at Jan 23, 2011, 4:16:54 PM |
Re: Wall is missing in 3D Did you check its height? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KandW at Jan 24, 2011, 4:12:54 PM |
Re: Wall is missing in 3D Thank you. The wall measures 241 cm |
| Posted by KandW at Jan 24, 2011, 4:15:28 PM |
Re: Wall is missing in 3D I mean the height measures 241 cm |
| Posted by hansmex at Jan 24, 2011, 4:38:13 PM |
Re: Wall is missing in 3D KandW, If you email me your file, I will be happy to look at it and explain you what went wrong (if anything). Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by KandW at Jan 26, 2011, 6:55:42 AM |
Re: Wall is missing in 3D Thanks to 'hansmex' I learned that the wall was n o t missing. It only was invisible because I looked on the 3D plan in an ancle I could not see it. The typical mistake of a SH3D beginner. |
Current timezone is GMT Oct 3, 2026, 10:51:13 PM |
