Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: How do I add a new button to the toolbar in the Sweet Home 3D applet? |
| Print at Sep 30, 2026, 11:12:45 PM | |
| Posted by Bluman at Jan 29, 2011, 3:54:02 PM |
How do I add a new button to the toolbar in the Sweet Home 3D applet?I have only partially figured out how I add a button to the toolbar in the applet. After a lot of work, I managed to add a button without functionality. This button was really supposed to split walls. It disappears when I press another button. How do I add a button permanently to the toolbar, and how do I add functionality to a button? By the way, how do I add an icon to such a button? |
| Posted by Puybaret at Jan 29, 2011, 5:18:06 PM |
Re: How do I add a new button to the toolbar in the Sweet Home 3D applet? In the method createHomeController of the com.eteks.sweethome3d.applet.AppletApplication class, you should call: toolBar.add(getToolBarAction(homeView, HomeView.ActionType.SPLIT_WALL));If you want to program a new button, implement a new Action and its actionPerformed method, then add the action to the toolbar. If you want to change its icon use the SMALL_ICON value of an action. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Bluman at Jan 30, 2011, 1:54:37 PM |
Re: How do I add a new button to the toolbar in the Sweet Home 3D applet? Thanks a lot. Now I can create buttons with my own actions. But I still have the problem that the SPLIT_WALL button disappears. Is it because "HomeView.ActionType.SPLIT_WALL" has no action? How do I combine this enum entry with an action? |
| Posted by Puybaret at Jan 30, 2011, 7:04:43 PM |
Re: How do I add a new button to the toolbar in the Sweet Home 3D applet? It's probably because you didn't define an icon for SPLIT_WALL action. Edit src/com/eteks/sweethome3d/swing/package.properties file and define in it the HomePane.SPLIT_WALL.SmallIcon property (look at other actions to guess how it works). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 11:12:45 PM |
