Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: strange walls across my room |
| Print at Oct 17, 2026, 9:47:11 AM | |
| Posted by KriZ99 at Feb 7, 2011, 9:06:08 PM |
strange walls across my room Hello, I've used this sweet program today for the first time and realy like it. There's only one problem, I have: There is a strange wall across my room wich is only visable in 3D (Areal View and virtual visit). And there is a 2nd wall between the left window. When I delete all walls, the wrong ones disappear, too. But I don't manage it to get these two wall out of my project. Maybe someone can take a look at my files and tell me, what I'm doing wrong. Thank you... klick |
| Posted by hansmex at Feb 7, 2011, 9:22:40 PM |
Re: strange walls across my room Kriz, It's not a wall, but a stray part of a ceiling. When your walls aren't the same height, SH3D cannot calculate a proper ceiling. This results in "strange" triangles, visible from one side, invisible from the other side. Make all walls 330 cm high, and they will disappear. If that is not possible, make the ceiling invisible. You may also want to study how to insert doors and windows: the way you inserted the two green doors shows you didn't make an exhaustive study of the manual... Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by KriZ99 at Feb 8, 2011, 10:50:54 AM |
Re: strange walls across my room Hello Hans! Make all walls 330 cm high, and they will disappear. Thank you, this helped! You may also want to study how to insert doors and windows: the way you inserted the two green doors shows you didn't make an exhaustive study of the manual... Sometimes reading the manual really helps. Now everything looks great. Chris |
| Posted by wrosun at Feb 9, 2011, 1:48:19 PM |
Re: strange walls across my room you really need to read the manual.i see you are using small wall heights to place windows into your model which is not necessary cause SH3D automatically creates a hole when you put your window or door model into the wall. Give sometime to read the manual and see the difference in the models you produced above and the perfect models you would be able to make with Sweet Home 3D.And remember to share your work in gallery forum for the world to see! Wrosun. |
| Posted by KriZ99 at Feb 9, 2011, 7:18:50 PM |
Re: strange walls across my room i see you are using small wall heights to place windows into your model Meanwhile I found out, how to handle this. Works fine. And remember to share your work in gallery forum for the world to see! Definitely... ![]() |
Current timezone is GMT Oct 17, 2026, 9:47:11 AM |
