Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Cut out |
| Print at Oct 5, 2026, 12:25:26 PM | |
| Posted by quickmic at Feb 11, 2011, 5:29:48 PM |
Cut out Hello First a big thanks for this program, but I have a problem. I need a kind of cut-out-tool to make holes in a wall with angle and without a frame. I need this for my top floor flat, so is there anything I can use? thx |
| Posted by Puybaret at Feb 11, 2011, 6:13:02 PM |
Re: Cut out Import the invisible box selecting the Door or window option during the 3rd step, and use one or more boxes of this kind to cut any wall or group of walls (it will cut only walls). See also this discussion. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by quickmic at Feb 11, 2011, 6:55:17 PM |
Re: Cut out Hmm, I implement the invisible box, but after small test it doasn't solve my problem. I will check the thread... thx |
| Posted by hansmex at Feb 11, 2011, 8:17:20 PM |
Re: Cut out Mic, Maybe this invisible hatch will solve your problem? And eh, don't forget to check Door/Window while importing, or it won't insert itself in the wall. Hans ---------------------------------------- ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by quickmic at Feb 13, 2011, 8:10:28 AM |
Re: Cut out Now it works basically. check Door/Window while importing... was my mistake, thx for the hint Problem is, I need an invisible wall/box or whatever which can make an angle on the top. Same system as normal wall have...sloping wall. Is this possible? |
| Posted by hansmex at Feb 13, 2011, 10:19:12 AM |
Re: Cut out Mic, Maybe you can apply a transparent texture to (a part of) the wall? It will show up as black in the design, but will be invisible when you make a photo render. Hans ---------------------------------------- ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by wrosun at Feb 13, 2011, 10:54:58 AM |
Re: Cut out Problem is, I need an invisible wall/box or whatever which can make an angle on the top. Same system as normal wall have...sloping wall. Is this possible? Are you trying to do something like this???? ![]() Design created by Macfrog Click to browse to the Original thread if it is so then its quiet simple...? let me know if its the same thing you are trying to do or not?? |
| Posted by quickmic at Feb 13, 2011, 2:36:51 PM |
Re: Cut out Something like this.... The red area has to be removed. ![]() |
| Posted by quickmic at Feb 13, 2011, 2:39:36 PM |
Re: Cut out That are dormers. |
| Posted by hansmex at Feb 13, 2011, 3:40:17 PM |
Re: Cut out Mic, Share your design, or send it to me. I don't understand exactly what you want. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by quickmic at Feb 13, 2011, 3:52:56 PM |
Re: Cut out Here it is https://rms-systems.homelinux.net/download/Transfer/flat/ I have also made some pictures. |
| Posted by hansmex at Feb 13, 2011, 4:33:59 PM |
Re: Cut out Mic, I still haven't looked at your files (the download is very slow), but I've seen the pictures. Some time ago I wrote a manual that explains how to make a dormer. You may want to study it, because I think it solves your problem. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by quickmic at Feb 13, 2011, 4:40:43 PM |
Re: Cut out My upload from my server only 512kbit :( I compressed the file.... I will check the howtodo, thx |
| Posted by quickmic at Feb 13, 2011, 4:55:21 PM |
Re: Cut out I think I got it.... Good manual! |
| Posted by soul at Mar 18, 2011, 11:18:25 PM |
Re: Cut out i used hatch and invisible box in door windows selection when importing but they just dont create a whole on wall?!?! |
| Posted by soul at Mar 18, 2011, 11:32:45 PM |
Re: Cut out i did read the how to make a dormer how to make a dormer. i cant see TOOLS section on my sweet home 3D !!!! |
| Posted by Puybaret at Mar 19, 2011, 12:43:39 PM |
Re: Cut out i used hatch and invisible box in door windows selection when importing but they just dont create a whole on wall?!?! You probably forgot to check the Door or window check box during the 3rd importing step. Only doors or windows can make holes in walls.i did read the how to make a dormer how to make a dormer. i cant see TOOLS section on my sweet home 3D !!!! You probably forgot to install some plugins as mentioned in the introduction. I feel you want to go to fast. I you take your time to read manuals entirely (they are not so long), you'll get many answers by yourself.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by soul at Mar 19, 2011, 4:37:50 PM |
Re: Cut out thank you, i have understood the settings about it, i clicked doors and windows box in 3rd import level, my mistake was that i thought i have to import them to doors and windows category, i misunderstood it i guess... so u say tools are added when i make the plugin, ok i will read more carefully,and then add that tools plug-in when i m ready to .. well that software is just awesome and just what i needed, i m tryna search and get every set ups to create what i imagine, thanks... |
| Posted by Puybaret at Mar 19, 2011, 7:03:32 PM |
Re: Cut out "Doors and windows" category is just a name, but I understand it's a little miselading. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stef.salmon at Nov 4, 2018, 12:02:27 PM |
Re: Cut out Hi, Sorry to reopen this! I have imported the invisible box and checked the door/window box, but if I then try to drop a door onto the box it won't snap to it and create a cutout. Am I doing something wrong? |
| Posted by Mike53 at Nov 4, 2018, 5:19:43 PM |
Re: Cut out You may need to disable magnetism while positioning them. Mike |
| Posted by stef.salmon at Nov 4, 2018, 5:25:15 PM |
Re: Cut out Hi Mike, If I disable magnetism I can line up the door, but it doesn't cutout the invisible box like it does on a normal wall. |
| Posted by Puybaret at Nov 4, 2018, 5:33:27 PM |
Re: Cut out Invisible boxes don't cut other pieces of furniture. They only cut walls and floors as show in this tip. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stef.salmon at Nov 4, 2018, 5:47:08 PM |
Re: Cut out Is there a way of having a transparent wall with a door? I have managed to put in some transparent glass walls, but now I just need to add a door which actually has a cutout. https://www.dropbox.com/s/ec2gvrl4mr89688/KWS_SS.png?dl=0 |
| Posted by Mike53 at Nov 4, 2018, 6:11:28 PM |
Re: Cut out Not sure i understand correctly, but have you thought to insert the door into a wall with its opacity set to nearly clear, then exporting both the door and the wall? |
| Posted by stef.salmon at Nov 4, 2018, 6:49:01 PM |
Re: Cut out Never tried to create an object before! That worked a treat...thanks Mike ![]() |
| Posted by Mike53 at Nov 4, 2018, 6:55:15 PM |
Re: Cut out Thank the lord its nearly january, i only get 1 good idea a year. Mike |
Current timezone is GMT Oct 5, 2026, 12:25:26 PM |
