Print at Sep 28, 2026, 10:56:44 PM
Posted by franck5525 at Mar 4, 2011, 2:41:06 PM
applause   Mac / Pc compatibility
Hello,
When i save a home under Mac OS, i can't open it under Windows XP ( error message : can't open home ) ; Is there a way to solve that ?
I use the last downloadable version on both computers.
Also, there is no 'Print to PDF' option under Mac version, is that normal ?
At least, we can export Plan to SVG format, but it seems that it is not possible to import from this format, am i right ?
By the way, it is a great software, thanks to developpers !
Regards,
Franck.
Posted by Puybaret at Mar 4, 2011, 3:12:40 PM
Re: Mac / Pc compatibility
It really works, I do it very often and all files in the gallery were drawn under Mac OS X. How did you transfer sh3d files from Mac OS X to Windows?
It's useless, since the "Print to PDF" is a standard feature in Mac OS X print dialog box.
What would you like to import from SVG?
Posted by franck5525 at Mar 4, 2011, 3:35:57 PM
Thanks for the quick response !
I send it as a mail attachment ( Max OS X at home -> Windows at work )
OK, i should have tried that before ! it was the goal i wanted to reach, ( sending the plan to a friend that is not 'computer fluent' at all ; so PDF format was the perfect way )
However, i found a work around : Gimp can open .SVG files pretty well and export to whatever format ...
So the problem is solved.
Thanks !
