Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Bad video quality |
| Print at Sep 28, 2026, 9:16:44 PM | |
| Posted by ld79 at Mar 8, 2011, 8:01:41 AM |
Bad video quality Hi, (Sorry for my english,I use google translate.) I was looking for here in the forum but could not find a similar problem. I'm trying to create a video with best quality or one step below but the result video quality is bad. Only the same rendering in the 3d view+shadows is good. I thought that something went wrong on the textures that I've done. I tried different resolutions but the result was always the same. Finally I downloaded SweetHome3DExample3.sh3d has also tried, but the result was the same. Check out this sample video: SweetHome3dExample3 (Download the video to see better the problem.) Sample picture from my video: Link The whole video is very noisy. What should have to set to be good? Thanks in advance for your help. |
| Posted by Puybaret at Mar 8, 2011, 8:24:16 PM |
Re: Bad video quality I don't think it's so bad. You've got what you get for a faster computing. If you don't like it, use the best quality or a larger resolution, before reducing it with a video tool. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 9:16:44 PM |
