Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problems updating from Version 2.6 to 3.1 |
| Print at Sep 28, 2026, 11:31:48 AM | |
| Posted by Trav at Mar 17, 2011, 2:28:02 AM |
Problems updating from Version 2.6 to 3.1 I have downloaded Version 3.1 a few times but whenever I go into Control Panel/Programs/Programs and Features Version 2.6 of Sweet Home 3D is the only one showing. I cannot understand why this is happening, so I was considering removing version 2.6 from my PC then downloading Version 3.1 again. If I remove Version 2.6 from Control Panel/Programs/Programs and Features will the house plans I have already prepared be lost? Is there something I am not doing correctly? Any help would be greatly appreciated. |
| Posted by Trav at Mar 17, 2011, 6:01:17 AM |
Re: Problems updating from Version 2.6 to 3.1 Since my previous post I have deleted my previous version of Java... Version 6(Update 23)and installed Version 6 Update 24 (the latest). I am using Windows 7 on a 64 bit PC and have Internet Explorer 9 as my browser.After I updated Java I downloaded Version 3.1 of Sweet Home 3D again!!!! Everything seemed to be working fine and when I clicked on Help and About in the Menu bar it showed that I was working in Version 3.1. I closed the program and now, when I right click on the Sweet Home 3D desktop icon it shows the version as Version 2.6 instead of 3.1. Please help this newbie. Thank you. |
| Posted by Puybaret at Mar 17, 2011, 7:19:47 AM |
Re: Problems updating from Version 2.6 to 3.1 Don't worry about the version shown on the desktop icon. The version you should trust is the version displayed by the About dialog. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Trav at Mar 17, 2011, 8:24:03 PM |
Re: Problems updating from Version 2.6 to 3.1 Emmanuel, Even the About dialog shows I am using Version 2.6, so something is wrong. |
| Posted by Trav at Mar 17, 2011, 8:31:15 PM |
Re: Problems updating from Version 2.6 to 3.1 Emmanuel, If I delete the Sweet Home 3D program (Version 2.6) via Control Panel will I lose all the house plans I have already developed? I cannnot afford to waste all the time spent on preparing those plans. Thank you. |
| Posted by Puybaret at Mar 17, 2011, 9:39:30 PM |
Re: Problems updating from Version 2.6 to 3.1 You won't lose your plans, and you won't even loose the furniture and textures you imported. I anticipated that. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Trav at Mar 17, 2011, 10:42:06 PM |
Re: Problems updating from Version 2.6 to 3.1 Many thanks Emmanuel. My problem appears to be solved. You are a whizz!!! |
Current timezone is GMT Sep 28, 2026, 11:31:48 AM |
