Print at Sep 27, 2026, 12:03:34 PM
Posted by dubrocards at Mar 18, 2011, 1:57:24 PM
Sweet Home 3D don't execute
Hi everyone,
I'm using SH3D (v3.0) durng several days without problem.
Since 4 days now when I launch SH3D i just have the screen "Sweet Home 3D" and it stay on the display. I must kill the process in the task manager.
I reinstall the SH3D v3.0 then v3.1. The problem is still there.
I reinstall Java, then SH3D. The problem is still there.
I follow the FAQ, but it don't work for me.
My configuration is :
- Core 2 Duo Intel 3 GHz
- 4 Go of RAM
- Windows 7 Pro (64 bits)
- nVidia GeForce 9500 GT (512 Mo)
Somebody can help me ?
Thanks
Posted by Puybaret at Mar 19, 2011, 12:49:18 PM
Re: Sweet Home 3D don't execute
If the program used to run and you tried every tip cited in the 3D problems FAQ, I would suspect a recent update of your video card driver.
Did you try also to increase max memory? Setting a number too big could prevent the program from running.
Posted by dubrocards at Mar 19, 2011, 3:32:15 PM
No I didn't increase memory.
After I had this problem I update the video card driver but the problem is still there.
I had at home this configuration :
- Athlon 4200+
- 4 Go of RAM
- Windows 7 Pro (64bits)
- nVidia GeForce 9500 GT (1024 Mo)
And everything work fine.
I don't know what I can do ?
Thanks again for any help.
Posted by dubrocards at Mar 21, 2011, 5:04:44 PM
Hi everyone,
Sweet Home 3D work again on my office desktop.
I deleted SH3D, Java and my graphic's drivers.
I deleted also all de directories SH3D and Java in subdirectorie "user\AppData\Roaming" and "user\AppData\Local".
Then I installed graphical's drivers, SH3D and JAVA.
Everything run fine now.
Thanks for reading me.
