Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problems by overlaying an object in another |
| Print at Sep 27, 2026, 10:16:10 AM | |
| Posted by yukisekisan at Apr 1, 2011, 12:24:48 AM |
Problems by overlaying an object in anotherHi, sorry for my poor english, I am spanish and i'm using a traductor for this. My problem is I'm trying to do a kitchen. I try to put a sink on top of a countertop overlay (which really is an object "box" modified program) and I see the sink cut in top. How I can superimpose the sink to make a hole in the countertop? Thank you very much and best regards. |
| Posted by Puybaret at Apr 1, 2011, 8:56:49 PM |
Re: Problems by overlaying an object in another Sweet Home 3D is able to compute holes only in walls where you place doors or windows. In your case, please design your sink cabinet with a general 3D tool like Art of Illusion or Blender, then import the model you created in Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Apr 1, 2011, 9:38:29 PM |
Re: Problems by overlaying an object in another Yuki, Of course you could also follow the roof tutorial (pdf). Make a wall the size of your counter top, insert an invisible box for the hole, then use CopyAsNewFurniture (pdf), and export the part. While importing you rotate it 90 degrees, and you can use it as a counter top with a hole for the sink. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by yukisekisan at Apr 2, 2011, 12:38:55 AM |
Re: Problems by overlaying an object in another Ok, thanks for all!. :) |
Current timezone is GMT Sep 27, 2026, 10:16:10 AM |
