Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Wall Drawing Preferences |
| Print at Sep 27, 2026, 3:01:32 PM | |
| Posted by connomar at Apr 9, 2011, 4:40:32 PM |
Wall Drawing Preferences Hi, I've seen some discussion on various ways of drawing a room, but I wonder if a fairly simple solution might work best. If we were able to select whether the length of a wall was measured from inside edge of the adjoining wall, then drawing a room to given dimensions would be much simpler. Also, would it be possible to press a secondary key and lock the vertical or horizontal plane whilst moving a wall. i.e. Inside dimension of a room is 60cm out and I want to move the wall. At present, this doesn't seem possible in a precise way. Thanks Martin |
Current timezone is GMT Sep 27, 2026, 3:01:32 PM |
