Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Question about 3DS rendering |
| Print at Oct 4, 2026, 8:47:00 PM | |
| Posted by LucasRey at Apr 12, 2011, 9:18:38 PM |
Question about 3DS rendering Hello people I'm a new (and happy) user of Sweet Home 3D... For sure I'm a newbie user and I've a little problem with 3DS object rendering. I downloaded many models from the Archive3D site, but all the time I've problem with rendering. For example from this model: http://archive3d.net/?a=download&id=33954 If I import into Sweet Home 3D this is the result :-( http://img130.imageshack.us/img130/3734/image002n.png Could someone help me? |
| Posted by hansmex at Apr 12, 2011, 10:47:24 PM |
Re: Question about 3DS rendering Lucas, Best thing you can try is import the model into Blender, than export ot from there as an OBJ file. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by LucasRey at Apr 13, 2011, 8:09:00 AM |
Re: Question about 3DS rendering Thanks Hans for interesting approach. Btw, I tried to import/export my previous example model, but nothing changes. Maybe I have to use also the texture contains into the zip file... OK it's to hard for me, since I never use a cad, drawing or rendering application! Probably I'll use the default models! :-) |
| Posted by db4tech at Apr 13, 2011, 9:31:06 AM |
Re: Question about 3DS rendering Hi Lucas, I also found, many of the models on archive3d.net are not as they appear in the sample download image. Many are corrupt and textures are present but not applied. When starting out, there are many good models on Sweet Home 3D model page or try Google 3D warehouse, thanks to Emmanuel the ones in Collada format can be imported into Sweet Home 3D. Thanks, David |
| Posted by hansmex at Apr 13, 2011, 11:30:45 AM |
Re: Question about 3DS rendering There are many nice columns in the Sketchup Warehouse. Start your Warehouse search with filetype:zip and you will get only models that can be directly imported in SH3D. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by LucasRey at Apr 13, 2011, 11:51:34 AM |
Re: Question about 3DS rendering Guys, thanks for Google 3D warehouse tips! I've still texture problem with some Collada models coming from Google, but in general all appear fine. Hans could you please clarify: "Start your Warehouse search with filetype:zip and you will get only models that can be directly imported in SH3D." ??? Or better, give me an example? I don't understant what are you saying! :-( |
| Posted by hansmex at Apr 13, 2011, 1:25:23 PM |
Re: Question about 3DS rendering Lucas, 1 - Warehouse search Try this query: filetype:zip column Select the image that interests you, and click it. Now underneath the preview image, pull down the Download Image menu, and you will see that the last format offered is the Collada (.zip) format. 2 - Collade texture problems See this thread (the one of April 12, 9:23 PM). Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by LucasRey at Apr 13, 2011, 2:49:51 PM |
Re: Question about 3DS rendering Perfect Hans, now is clear! Thank you for all your help! |
Current timezone is GMT Oct 4, 2026, 8:47:00 PM |
