Print at Sep 28, 2026, 6:20:40 PM
Posted by vinnyk at Apr 30, 2011, 9:18:16 AM
lost everything
as a new starter I did a floor plan of my house and added the furniture etc but near the end everything just disappeared !!! I must have clicked something but I dont remember what...........any help/advice would be welcome. I use win 7. thanks vinnyk
Posted by Puybaret at Apr 30, 2011, 10:40:12 AM
Re: lost everything
What version do you use?
Posted by vinnyk at May 1, 2011, 12:05:04 PM
Re: lost everything
just had a look and it is 3.1 is this any help
Posted by vinnyk at May 1, 2011, 4:13:18 PM
Re: lost everything
as a more detailed explanation when I say everything has disappeared the plan is now just plain white with nothing else, no graph or furnishing etc that were imported ............ just nothing !!! vinnyk
Posted by Puybaret at May 1, 2011, 4:19:10 PM
Re: lost everything
Send it to me, I'll see if I can recover it.
To other readers, be sure to always use the latest version of Sweet Home 3D. Among the "other minor bug fixes" cited in history, there are often changes that should avoid the kind of problem reported by vinnyk.
Posted by Puybaret at May 1, 2011, 5:36:00 PM
Re: lost everything
I was able to fix vinnyk's issue.
It was probably because of a very thin 3D model he imported, and actually, I made some small changes in version 3.2 to avoid such problems. Hopefully, the same kind of issue shouldn't happen again.
Posted by vinnyk at May 2, 2011, 7:58:15 AM
Re: lost everything
once again thanks to Emmanuel for the help
Posted by lu180 at Jan 19, 2013, 3:43:19 AM
Re: lost everything
Help! I was using the online version and lost everything as well. White screen and no graph.
Posted by Puybaret at Jan 19, 2013, 3:45:40 PM
Re: lost everything
Lu180, I fixed the file that was wrong, but I had to remove 3 incorrect walls and a door frame.
