Print at Sep 28, 2026, 11:26:40 PM
Posted by Frador2 at May 9, 2011, 9:53:16 PM
Removing objects from library
Is it possible to remove objects from the library once I've imported them? I thought I read somewhere that it was possible, but I can't find where I read it.
Posted by hansmex at May 9, 2011, 10:02:35 PM
Re: Removing objects from library
Frador,
How you remove a model from the library, depends on how the model was added.
1 - You imported the model
Just right-click on the model, and choose delete.
2 - The model is a model that came in a library file (SH3F)
Use the LibraryEditor (see manual PDF) to open the library. Delete the file from the library.
Posted by wrosun at May 10, 2011, 4:20:04 AM
well about this.I inported furniture through some .sh3f file i created before and now there are some furnitures which appear more then twice in the library any tip for removing those.
can furniture library editor help me....?
Posted by hansmex at May 10, 2011, 6:59:47 AM
wrosun,
Read the previous post, please.
Posted by Frador2 at May 10, 2011, 2:10:53 PM
It was from a library file. I have the Library Editor, but where can I find the library or libraries to edit them? I've looked everywhere I can think of. Obviously I'm missing somewhere.biggrin
I even tried to uninstall and reinstall SH3D, but all the libraries I imported are still there, even with the new install.
Posted by Frador2 at May 10, 2011, 2:13:19 PM
Just a quick note. I love this program. applause applause applause
Posted by Puybaret at May 10, 2011, 2:52:16 PM
See the Libraries of additional 3D models section in the 3D models page.
Posted by Frador2 at May 10, 2011, 5:02:29 PM
Found the solution and I'm including it here so it's here for anyone else to find.
I use Windows 7 and the App Data folder is a hidden file. If you can't find it, you have to go to Control Panel\ Appearance and Personalization\ Folder Options and check Show Hidden Files, etc.
