Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: render can be pause or resume |
| Print at Sep 24, 2026, 5:48:01 AM | |
| Posted by fhoofman at May 23, 2011, 1:08:22 PM |
render can be pause or resume I've been rendering for more than 15 hours. and suddenly lights got out. and every hours rendering work gone .... I have UPS and only last 15 minutes. is there anyway to save the rendering and resume other time? thanks a lot |
| Posted by Puybaret at May 24, 2011, 7:30:44 AM |
Re: render can be pause or resume Sorry Yudi, but I don't think you can recover anything. If you were computing an image, it's sure you can't recover anything (no temporary file matching what you see at screen is created). If you were computing a video, frames are stored in a temporary file but from my past tests, this file is valid only when the video is finished. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by macfrog at May 25, 2011, 5:51:23 PM |
Re: render can be pause or resume fhoofman, you should always be able to send your computer to hibernate, therefore all the computing stops and you can resume after power goes on! macfrog |
| Posted by fhoofman at May 26, 2011, 2:02:17 AM |
Re: render can be pause or resume how about this. since the program can store store point of view, I wish the program can divide into 4 or 8 screen. each render screen that has complete, the program can store the screen in temporary. after all screen complete, the program can joint all screen. this is the simple method on my mind. but I don't know how to make it whatsoever |
| Posted by Puybaret at May 26, 2011, 7:03:09 AM |
Re: render can be pause or resume Good try. But on an optical point of view, it doesn't work this way! Test it yourself with a camera (on a tripod at best), and you'll see your 4 or 8 images won't superimposed nicely at their borders. That's why some people created programs to build panoramas like Hugin! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 5:48:01 AM |
