Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Lights?? |
| Print at Oct 3, 2026, 12:20:55 AM | |
| Posted by Klenne at May 29, 2011, 10:27:19 AM |
Lights??Hi I've a big problem with putting lights into my plan. I've put lights where I wanted them. Now I've read that I've to put a source into the light. I did do that. But I get only a white little thing. No lights...:s How can I see the light in my 3D-plan? |
| Posted by macfrog at May 29, 2011, 9:10:41 PM |
Re: Lights?? Klenne, you can only see the light (or the symbol for the light source), wenn you activate it (e.g. by clicking). the LIGHT ITSELF is only visible in the final render (create photo, quality 3 or 4). So, the whitle little thing is a wireframe sphere - the light source. btw. when you use the included lamps instead of importing your own one you don't have to add a light source. Sometimes, when you add your own light source into your design, the light source (which is basically a sphere) gets partially hidden by surrounding objects/walls etc.. Therefore it might be invisible in the final render or there might be black spots instead of a light and so on. hope this helps a bit. macfrog below: screenshot of a selected light src: ![]() |
Current timezone is GMT Oct 3, 2026, 12:20:55 AM |
