Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: electric installation |
| Print at Oct 8, 2026, 6:26:55 AM | |
| Posted by noxx at Jul 1, 2011, 9:20:10 AM |
electric installation is it possible to add a complete electric installation in my rooms (cable, circuits,...)? and is it possible to add dimensioning for the walls? regard |
| Posted by hansmex at Jul 1, 2011, 9:59:15 AM |
Re: electric installation Ralf, There is no ready to use system to design electrical systems, plumbing, and such. You can invent it yourself, though... Dimensioning is a standard feature in SH3D. Or did you mean something else...? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Jul 1, 2011, 10:01:00 AM |
Re: electric installation Even if it could come sooner than expected, the current version of Sweet Home 3D doesn't have any tool to help you draw "free" colored lines in the plan. If you need some electric symbols, you could check if the font used by Sweet Home 3D supports the Unicode symbols that could help you. If you want to draw dimensions on the walls, use the dimension creation tool and double click on the walls where you want a dimension. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by noxx at Jul 1, 2011, 9:22:49 PM |
Re: electric installation Even if it could come sooner than expected, the current version of Sweet Home 3D doesn't have any tool to help you draw "free" colored lines in the plan. If you need some electric symbols, you could check if the font used by Sweet Home 3D supports the Unicode symbols that could help you. If you want to draw dimensions on the walls, use the dimension creation tool and double click on the walls where you want a dimension. i mean the dimensions from walls in x,y AND Z axis. |
| Posted by Puybaret at Jul 2, 2011, 2:14:28 AM |
Re: electric installation i mean the dimensions from walls in x,y AND Z axis. How would you draw that information?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by noxx at Jul 2, 2011, 7:10:22 AM |
Re: electric installation perhaps: -> 3D Dimension http://www.stadtwerke-garbsen.de/CMS/ContentF...arbsen/Images/HA_Raum.jpg but i think this is a wish or feature request. :) thx for your answer regard |
| Posted by macfrog at Jul 2, 2011, 9:37:35 PM |
Re: electric installation noxx, as for sh3d, you can only add measurements in 2D for the top-view, there is no solution for adding those for the vertical axis. this would require a side/front view. sh3d is used to be a "Möbelschubser" (long time ago), with an excellent(and growing) surrounding design engine (thanx for that). so, if you need a "real" installation software, get eplan, or acad, or whatever. macfrog p.s.: if you consider revealling your home as Germany, you might get answers in the "foreign language" chapters of this forum in your natives... |
Current timezone is GMT Oct 8, 2026, 6:26:55 AM |
