Print at Sep 29, 2026, 6:38:46 AM
Posted by Moleu at Jul 18, 2011, 12:11:33 AM
sad   I can't import the furnitures in my project
Hello people.
I'm having a big problem because I can't import new furnitures im my project.
when I will finish the importation, appears a message:
"Can't save preferences in file system"
Is impossible to install new furnitures and new textures.
I made everything possible to fix this problems, I installed the newest version of Java, I updated the Flash Player, the video card drivers are ok.
Please guys, help me......
Posted by Moleu at Jul 18, 2011, 12:37:24 AM
Re: I can't import the furnitures in my project
Posted by Moleu at Jul 25, 2011, 2:52:16 AM
Nobody knows?
Posted by Puybaret at Jul 25, 2011, 5:49:42 AM
This error can happen if you don't have write access to applications data folders. But if this is the case, other applications shouldn't work correctly too...
On what system do you use Sweet Home 3D?
Posted by Moleu at Jul 25, 2011, 4:58:08 PM
I'm using Windows Xp Professional SP3 (build 2600), videocard: GeForce 8400GS, Sweethome 3.2 version.
About other applications I haven't similar problems.
Previously I've used this program without issues.
I formatted my pc with the same Windows that I used previously, after installing Windows I can't use normally Sweethome.
But, what I could do to enable write acess?
Thanks for helping......
