Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How can I adjust the memory used by Sweet Home 3D? |
| Print at Sep 27, 2026, 12:05:25 PM | |
| Posted by xpat at Aug 13, 2011, 3:26:29 PM |
How can I adjust the memory used by Sweet Home 3D? Hello, Can someone teach me? 1.Where can I find the folder "SweetHome3D.exe" 2.How to write Java option in that file? 3.I have installed "64 bits version of Java" and downloaded the Jar executable version, how to execute the java to 2G or more? Is it automatic? Many Thanks Xpat |
| Posted by Puybaret at Aug 13, 2011, 3:49:56 PM |
Re: How can I adjust the memory used by Sweet Home 3D? Did you try the suggestions in the FAQ How can I adjust the memory used by Sweet Home 3D? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by xpat at Aug 14, 2011, 2:17:55 PM |
Re: How can I adjust the memory used by Sweet Home 3D? I have read the FAQ already, but get confuse with the steps, I am using Win7 and I cannot create text file in "C:\Program Files (x86)\Sweet Home 3D" |
| Posted by Puybaret at Aug 21, 2011, 6:27:24 PM |
Re: How can I adjust the memory used by Sweet Home 3D? If you don't have administrator rights, this will be indeed a problem. Why don't you try the other way with jar executable file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 12:05:25 PM |
