Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Swimming Pool |
| Print at Sep 26, 2026, 11:12:46 PM | |
| Posted by luxray8910 at Aug 19, 2011, 3:19:05 PM |
Swimming PoolHi, My home is pretty cool for now, but i would really like to add quite a bit more.... which includes an outdoor swimming pool. But i have realized that there are no swimming pool furnitures, and i cant exactly make one at a negative level, so please help. Is there a place i can import a hot tub or something? Once again, please help! ---------------------------------------- ~Kayla~ |
| Posted by hansmex at Aug 19, 2011, 3:28:38 PM |
Re: Swimming Pool Kayla, No need to ask your question three times... It will only be answered once. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by luxray8910 at Aug 19, 2011, 6:18:38 PM |
Re: Swimming Pool Kayla, No need to ask your question three times... It will only be answered once. Hans Sorry, I asked more than once because I really wanted an answer, as I do now on importing furniture. ---------------------------------------- ~Kayla~ |
| Posted by carlctz at Sep 20, 2011, 6:15:47 PM |
Re: Swimming Pool hi im a newbie here on the site but what i did is just use the square block object and make it the size of my pool then flatten it to 2cm and then imported a water texture that i used on it, I add 4 more blocks on the sides for the walls and flattened them to about 5cm then just added a paving texture on them. its not a perfect solution but it does the job. ---------------------------------------- I'm a self professed NOOB at almost anything in life into gaming, mobile web design and 3D animation or design software. |
| Posted by bteniente at Sep 20, 2011, 7:37:39 PM |
Re: Swimming Pool I would suggest adding a ladder from google 3d or somewhere else to give your pool a realistic touch :) |
| Posted by luxray8910 at Sep 20, 2011, 8:58:45 PM |
Re: Swimming Pool What I did was use a Carpet, make it as big as I wanted my in-the-ground pool to be, then change the texture to a water pattern. Then I took more of the Carpets and changed their textures to look like concrete and put it around the edges of my in-ground pool. It looks awesome so far! ---------------------------------------- ~Kayla~ |
| Posted by polo2010 at Sep 26, 2011, 5:53:09 AM |
Re: Swimming Pool You can also use a wall - make it the size of pool plus surroundings - place an invisible box the size of your pool where you want your water - copey as new furniture and add texture and so on... |
| Posted by polo2010 at Sep 26, 2011, 10:35:25 AM |
Re: Swimming Pool You can also use a wall - make it the size of pool plus surroundings - place an invisible box the size of your pool where you want your water - copey as new furniture and add texture and so on... BTW I posted a pict in the gallery that was made that way. Also you can use the "slope" in the wall settings to make elevated terrain. http://www.mediafire.com/i/?1jqcqgp1l6hjhf3 |
| Posted by alishaanne97 at Mar 5, 2012, 10:04:43 PM |
Re: Swimming Pool I used the flooring and made a big square the size that i wanted my pool and then used it again to put a boarder around it, used an imported water picture and a tile texture. |
Current timezone is GMT Sep 26, 2026, 11:12:46 PM |
