Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problems with applet on a webserver |
| Print at Sep 26, 2026, 1:05:53 PM | |
| Posted by dany74m at Aug 30, 2011, 9:16:04 PM |
Problems with applet on a webserver Hi, hello to all Im a new user of this fantastic software. Im tryng to put online a 3d model of an appartment I have done using the java applet. Offline it works, when I call the page trought a webserver it says that it cannot load the house. What am I doing wrong? I tried to replace the address in the html page with an absolute path, but it did not work. Please help! |
| Posted by Puybaret at Aug 31, 2011, 7:19:19 AM |
Re: Problems with applet on a webserver I tried to replace the address in the html page with an absolute path, but it did not work. Do you mean you used the absolute URL of your sh3d file in the homeURL parameter of your HTML document? Did you also try to directly enter this URL in the browser URL text field? What version of the viewer do you use?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dany74m at Aug 31, 2011, 8:51:57 AM |
Re: Problems with applet on a webserver Yes, I mean i replace the "defaul.shrd" path with "http://mysite/mydyr/defaul.sh3d" Im using the last version, just downloaded yesterday.What do you mean by entering direclty the url? Wich url, of the file .sh3d? |
| Posted by Puybaret at Aug 31, 2011, 10:57:39 AM |
Re: Problems with applet on a webserver Yes check you can download http://mysite/mydyr/myhome.sh3d directly from your browser. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dany74m at Aug 31, 2011, 12:51:34 PM |
Re: Problems with applet on a webserver thank you.. I will...so if not, it means I have to enable the download in the server directory? |
| Posted by dany74m at Aug 31, 2011, 11:18:54 PM |
Re: Problems with applet on a webserver I tryed, It says that it cannot find the file... and in my webserver I just can configure the permission to read or write....its weird.. |
Current timezone is GMT Sep 26, 2026, 1:05:53 PM |
