Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: New Plugin! |
| Print at Oct 13, 2026, 7:01:10 PM | |
| Posted by VRMachina at Sep 2, 2011, 3:04:52 PM |
New Plugin! Hi, i want to do a new plugin. I also want to do uml analysis while i build the plugin, to do it correctly ![]() |
| Posted by Puybaret at Sep 2, 2011, 3:18:42 PM |
Re: New Plugin! What kind of plugin do you want to program? If you look for ideas, a plugin able to display a cutting list or to generate stairs will be greatly appreciated. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by VRMachina at Sep 2, 2011, 6:17:56 PM |
Re: New Plugin! What do you mean by cutting list and generating stairs? |
| Posted by Puybaret at Sep 21, 2011, 7:00:23 AM |
Re: New Plugin! The cutting list idea came from this thread. Feel free to answer to the thread or write to its author to get more info than what you'll find with Google. A plug-in able to generate stairs could be able to create on the fly the icons and the 3D model of a staircase depending on the size of one stair and the ascending path that will bring someone from the bottom to the top of the staircase. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 13, 2026, 7:01:10 PM |
