Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: models importing w are missing their "skins" or photos/texture |
| Print at Sep 27, 2026, 3:01:35 PM | |
| Posted by dwillis at Oct 12, 2011, 11:01:53 PM |
models importing w are missing their "skins" or photos/texture When I import some COLLADA models into SweetHome3D (latest version) the models import but their "skin" or photo is missing. This maybe a problem with google sketchup. I download the model from the google 3d warehouse and it downloads it in a zip file packet with the model in .3ds format and the "photo realistic" "skin" it has is seperated into a image file below the model file. How do I put the "skin" back on the model in SweetHome3D? If you want to see what I am talking about just downloading this model: http://sketchup.google.com/3dwarehouse/detail...2074388cc&prevstart=0 and then try to import it into SH3D If you can fix this please let me know [email protected] Thank you |
| Posted by hansmex at Oct 13, 2011, 8:43:02 AM |
Re: models importing w are missing their "skins" or photos/texture Davis, Your description of the problem is a bit strange. The model you are linking to is a SKP model, not a ZIP/DAE (=collada) or 3DS model. There is a known problem with collada models: the orientation of faces (what you call skins). Think of a sheet of paper having two faces. The render engine used by SH3D (=Sunflow) has a problem deciding which face to show. You can solve this problem by importing your model into Sketchup and then using the function Edit --> Face --> Reverse faces. You then have to use File --> Export --> 3D model to export the file as a DAE model that SH3D can use. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 27, 2026, 3:01:35 PM |
