Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Setting the exact location of the export |
| Print at Sep 28, 2026, 12:56:12 PM | |
| Posted by Mitsaki at Nov 6, 2011, 7:24:47 PM |
Setting the exact location of the export Hello again, what I want to do is to modify the existing interface, so that when the export to .obj file runs, the window, that the user uses in order to save the project, doesn't run and the project is saved directly in a desirable path. Do you know where I should look to find the place that this is done, in which class? I would really appreciate it. Mitsaki |
| Posted by Puybaret at Nov 10, 2011, 12:00:42 AM |
Re: Setting the exact location of the export The path of the SH3D file is simply returned by the getName method of the Home object. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Mitsaki at Nov 10, 2011, 3:42:31 PM |
Re: Setting the exact location of the export To do what I need, I just used the class FileContentManagerand I added blocked comment in the row 471-475, so the dialog box does not appear, like this and as savedName I put Our_home. String savedName;The only thing that is missing now is to set the file, so that it is not saved automatically inside the sweethome3d folder, in workspace, but outside of it. |
Current timezone is GMT Sep 28, 2026, 12:56:12 PM |
