Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Duplicating object will not release the cursor |
| Print at Aug 9, 2026, 3:10:41 PM | |
| Posted by node105 at Nov 16, 2011, 2:31:06 AM |
Duplicating object will not release the cursor Hi, Mac OS 10.6.8 I have been creating a building drawing columns and girts using the Miscellaneous box object; which has been working fine. when duplicating an object however using click select option drag, it often gets histrionic, and will not release; the dragged duplicate will not drop as a new object and the cursor remains a green circular + , only closing the active window allows me to escape ( escape key, enter, return - none have any effect. Sometimes multiple objects get created as one tries to click drop the replicate, Sometime they appear to be created by the cursor is still locked... Is this a bug or should I be using a different approach? |
| Posted by Puybaret at Nov 16, 2011, 10:50:00 AM |
Re: Duplicating object will not release the cursor It looks like a bug. Does it happen all the time you duplicate? Do you use laptop or a trackpad? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by node105 at Nov 16, 2011, 11:34:33 AM |
Re: Duplicating object will not release the cursor it feels like a bug not all the time but 70% of the time ( maybe) One can end up with 6 or 7 copies of the object and the cursor will not release on an iMAc 27 8MB RAM using a mighty mouse Another bug seems to be adding .dae files; 2 separate examples have ground it to a halt, Activity Monitor shows sweetHome 3 D running 120+% of CPU wrt the problematic .dae Only quitting and deleting the furniture item from the left panel restores functionality Only my first day with SH3D, quite impressed, but clearly some issues |
| Posted by Puybaret at Nov 16, 2011, 3:22:57 PM |
Re: Duplicating object will not release the cursor Please give links to the DAE pages that caused some problems if possible. Maybe you chose too big files. Generally trees with too many details just slow down the software. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Nov 19, 2011, 11:41:23 AM |
Re: Duplicating object will not release the cursor node105, I have the same kind of computer, and couldn't reproduce your issue after many attempts with the current beta version 3.4. Sorry, you'll have to give more details to help me reproduce this bug. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by node105 at Nov 19, 2011, 9:47:50 PM |
Re: Duplicating object will not release the cursor testing this am choose model (zip) takes 2 minutes initial blue spinning ball, (then Apple multi coloured spinning pizza wheel Continue button remains greyed, Activity Monitor show SW > 100%, cursor can release back to pointer and Continue remains greyed - Force quit SW required I stress that this is not just one source file, I have had this happen with 3 different files. Just did 10 or 12 imports, and most were ok. THe one file (tree) caused a hang on 3 different import attempts, but imported ok on another 2 attempts My feeling is it is in the initial import sequence I did think that it may have been something to do with .zip files, but sometimes it works and others not, and has failed on import of the unpacked .dae as well. On some occasions the ( If the following information isn't correct, update it ) Name text in the wizard is red, then continue is not available, using the go back button, then continue usually makes it go black, but the Continue button remains greyed unless the name is changed At one point in repetition testing I felt it was not changing the default ( bathroom) import destination) to something els ( miscellaneous) that was the cause of the subsequent freeze, but testing this am, hangs have happened regardless THe file ( a tree) that initially caused , and occasionally continues to cause problems ( in re -import testing - having deleted, and quit…) is a tree Yes I did consider that it may be a file size issue expecting a tree render to be more complicated, but it has also happened on a different file ( but now do not know which one) ganyedes_s Aceraceae which I think I found in Google Sketchup as a Collada zip Attached log extract my help: 20/11/11 7:20:43 AM kernel Limiting closed port RST response from 297 to 250 packets per second 20/11/11 7:25:38 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] Exception in thread "AWT-EventQueue-0" 20/11/11 7:25:38 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:25:42 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] at javax.media.j3d.Shape3DRetained.doSetLive(Shape3DRetained.java:996) 20/11/11 7:25:45 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] at javax.media.j3d.Shape3DRetained.setLive(Shape3DRetained.java:975) 20/11/11 7:25:51 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:26:10 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] Exception occurred during event dispatching: 20/11/11 7:26:10 AM [0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653] Exception in thread "Poller SunPKCS11-Darwin" 20/11/11 7:26:12 AM com.apple.launchd.peruser.501[126] ([0x0-0x8d08d].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7653]) Exited: Killed 20/11/11 7:26:51 AM kernel Limiting closed port RST response from 288 to 250 packets per second 20/11/11 7:28:21 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "J3D-MasterControl-1" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:28:21 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at java.lang.reflect.Array.newInstance(Array.java:52) 20/11/11 7:28:23 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.IndexedUnorderSet.add(IndexedUnorderSet.java:404) 20/11/11 7:28:23 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderMolecule.removeRenderAtom(RenderMolecule.java:1686) 20/11/11 7:28:23 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderBin.removeARenderAtom(RenderBin.java:5907) 20/11/11 7:28:25 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderBin.removeAllRenderAtoms(RenderBin.java:5934) 20/11/11 7:28:25 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.RenderBin.cleanup(RenderBin.java:6913) 20/11/11 7:28:25 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.View.reset(View.java:3390) 20/11/11 7:28:32 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.MasterControl.handlePendingRequest(MasterControl.java:3320) 20/11/11 7:28:39 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.MasterControl.doWork(MasterControl.java:3121) 20/11/11 7:28:39 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.MasterControlThread.run(MasterControlThread.java:67) 20/11/11 7:28:41 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:28:43 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at java.util.ArrayList.<init>(ArrayList.java:112) 20/11/11 7:28:43 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.Shape3DRetained.<init>(Shape3DRetained.java:92) 20/11/11 7:28:45 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.Shape3DRetained.doSetLive(Shape3DRetained.java:996) 20/11/11 7:28:45 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.Shape3DRetained.setLive(Shape3DRetained.java:975) 20/11/11 7:28:46 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:28:46 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:28:48 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.setLive(GroupRetained.java:2188) 20/11/11 7:28:48 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:28:50 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:28:52 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:28:54 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:28:54 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:28:56 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:28:57 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.SharedGroupRetained.childDoSetLive(SharedGroupRetained.java:887) 20/11/11 7:29:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.setLive(GroupRetained.java:2188) 20/11/11 7:29:03 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.SharedGroupRetained.setLive(SharedGroupRetained.java:310) 20/11/11 7:29:04 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.LinkRetained.setLive(LinkRetained.java:178) 20/11/11 7:29:06 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:08 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:10 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:29:10 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:12 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:13 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:29:15 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:17 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:19 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.TransformGroupRetained.setLive(TransformGroupRetained.java:567) 20/11/11 7:29:19 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:21 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:22 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.BranchGroupRetained.setLive(BranchGroupRetained.java:187) 20/11/11 7:29:24 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.childDoSetLive(GroupRetained.java:2196) 20/11/11 7:29:26 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at javax.media.j3d.GroupRetained.doSetLive(GroupRetained.java:2249) 20/11/11 7:29:50 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "Poller SunPKCS11-Darwin" 20/11/11 7:29:52 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:29:55 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.wrapper.PKCS11.C_GetSlotInfo(Native Method) 20/11/11 7:29:57 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.SunPKCS11.initToken(SunPKCS11.java:767) 20/11/11 7:29:59 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.SunPKCS11.access$100(SunPKCS11.java:42) 20/11/11 7:29:59 AM Sweet Home 3D[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:29:59 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at sun.security.pkcs11.SunPKCS11$TokenPoller.run(SunPKCS11.java:700) 20/11/11 7:30:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] at java.lang.Thread.run(Thread.java:680) 20/11/11 7:30:01 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" 20/11/11 7:30:03 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:30:20 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:30:53 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] Exception in thread "AWT-EventQueue-0" 20/11/11 7:30:55 AM [0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:31:01 AM com.apple.launchd.peruser.501[126] ([0x0-0x94094].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7763]) Exited: Killed 20/11/11 7:39:00 AM kernel Limiting closed port RST response from 254 to 250 packets per second 20/11/11 7:40:39 AM kernel Limiting closed port RST response from 268 to 250 packets per second 20/11/11 7:44:52 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "Timer-0" 20/11/11 7:44:54 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.StringCoding$StringEncoder.encode(StringCoding.java:232) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.StringCoding.encode(StringCoding.java:272) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.String.getBytes(String.java:946) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.UnixFileSystem.canonicalize0(Native Method) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.UnixFileSystem.canonicalize(UnixFileSystem.java:157) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.File.getCanonicalPath(File.java:559) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.provider.PolicyFile.canonPath(PolicyFile.java:1849) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission$1.run(FilePermission.java:186) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission$1.run(FilePermission.java:183) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.security.AccessController.doPrivileged(Native Method) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission.init(FilePermission.java:183) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.FilePermission.<init>(FilePermission.java:249) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.SecurityManager.checkRead(SecurityManager.java:871) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.io.File.lastModified(File.java:824) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.tools.OperatingSystem$2.run(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.TimerThread.mainLoop(Timer.java:512) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.TimerThread.run(Timer.java:462) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "pool-11-thread-1" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.regex.Pattern.compile(Pattern.java:1451) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.regex.Pattern.<init>(Pattern.java:1133) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.regex.Pattern.compile(Pattern.java:823) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.String.split(String.java:2292) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.String.split(String.java:2334) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader$DAEHandler.endElement(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:601) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFra gmentScannerImpl.java:1782) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2939) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragm entScannerImpl.java:511) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.xml.parsers.SAXParser.parse(SAXParser.java:395) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.xml.parsers.SAXParser.parse(SAXParser.java:198) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader.parseXMLStream(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader.load(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.DAELoader.load(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.j3d.ModelManager.loadModel(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.swing.ImportedFurnitureWizardStepsPanel.readModel(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.swing.ImportedFurnitureWizardStepsPanel.access$1400(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at com.eteks.sweethome3d.swing.ImportedFurnitureWizardStepsPanel$37.run(Unknown Source) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) 20/11/11 7:45:03 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.Thread.run(Thread.java:680) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "Poller SunPKCS11-Darwin" 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.wrapper.PKCS11.C_GetSlotInfo(Native Method) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.SunPKCS11.initToken(SunPKCS11.java:767) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.SunPKCS11.access$100(SunPKCS11.java:42) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at sun.security.pkcs11.SunPKCS11$TokenPoller.run(SunPKCS11.java:700) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.lang.Thread.run(Thread.java:680) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ContainerModel.getSurfaceBounds(ContainerModel.java:70) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.CPeerSurfaceData.setBounds(CPeerSurfaceData.java:106) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ComponentModel.replaceSurfaceData(ComponentModel.java:531) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ComponentModel.getSurfaceData(ComponentModel.java:470) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at apple.awt.ComponentModel.getGraphics(ComponentModel.java:465) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2840) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JDialog.getGraphics(JDialog.java:1090) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at java.awt.Component.getGraphics(Component.java:2828) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.JComponent.getGraphics(JComponent.java:1932) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:784) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:694) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager.access$700(RepaintManager.java:41) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1672) 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] Exception in thread "pool-11-thread-2" 20/11/11 7:47:16 AM [0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940] java.lang.OutOfMemoryError: Java heap space 20/11/11 7:47:59 AM com.apple.launchd.peruser.501[126] ([0x0-0x9c09c].com.apple.jnlp-http___www.sweethome3d.com_SweetHome3D.jnlp[7940]) Exited with exit code: 143 |
| Posted by Puybaret at Nov 20, 2011, 8:04:12 AM |
Re: Duplicating object will not release the cursor Long import = big models = lot of memory, and from OutOfMemoryError appearing in the log, it's actually a memory problem. Even if you might find that weird, Java programs can't consume as much memory as they want. If you want to increase the max amount of memory the program can use in the downloadable version, please read the FAQ, but if I were you, I would simply forget the idea of using this model. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by node105 at Nov 20, 2011, 10:46:19 PM |
Re: Duplicating object will not release the cursor <<it's actually a memory problem. Even if you might find that weird,>> I do; it has been a very long time since I last had to reset a memory value As I indicated, it is not only this model, but was another much smaller ( just can't recall which one). Not as issue discarding the particular model I am well used to flaky Java; as a filemaker developer server user Actually 2 places in the .plist, and the existing value is not as the fq indicates (i.e. is not 1024) <key>Properties</key> <dict> <key>apple.awt.graphics.UseQuartz</key> <string>true</string> <key>apple.laf.useScreenMenuBar</key> <string>true</string> <key>jnlpx.heapsize</key> <string>NULL,536870912</string> <key>jnlpx.offline</key> <string>true</string> </dict> <key>VMOptions</key> <array> <string>-Xmx536870912</string> </array> THanks |
| Posted by Puybaret at Nov 20, 2011, 11:26:02 PM |
Re: Duplicating object will not release the cursor I am well used to flaky Java Hum, not sure you speak to the right person if you want to criticize Java! ;)I don't say Java is perfect, but without it, no portability and no Sweet Home 3D under Mac OS X! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by node105 at Nov 21, 2011, 10:38:59 PM |
Re: Duplicating object will not release the cursor We all have our crosses to bear :-) Mine's FileMaker |
| Posted by macfrog at Jan 4, 2012, 9:28:03 PM |
Re: Duplicating object will not release the cursor Emmanuel, i've encountered the mentioned duplicate bug as well, but not as often. it happened first on a very big file, so restarting helped to free memory (sh*tty Mac OSX). Last week it happens on a new small project, so i believe it's not a memory issue at all i'll try to nail it down. |
Current timezone is GMT Aug 9, 2026, 3:10:41 PM |
