Print at Sep 29, 2026, 7:22:28 PM
Posted by coldcomfort at Nov 27, 2011, 2:53:18 PM
about roofs
I have a problem with roofs. After i make one from a wall, i export/import as obj, I always get a surface (visible from only one direction in the 3dviewer but always showing up in pictures) where the ground used to be.
It always happens to me but I see pictures on the forum, without that surface...
...How do you get rid of it?
Posted by hansmex at Nov 27, 2011, 5:43:27 PM
Re: about roofs
CC,
Use SH3D version 3.3 and install the plug-in CopyAsNewFurniture (see tutorial PDF ). The plug-in copies your elements in a slightly different way, without the floor part.
The 3.4 beta version cannot handle the plug-in.
Posted by coldcomfort at Nov 27, 2011, 8:13:57 PM
Re: about roofs
Thank you, hansmex :). Now it works just right, with the CopyAsNewFurniture plugin.
