Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Video renderin speed low |
| Print at Oct 15, 2026, 4:42:55 AM | |
| Posted by Clovis at Dec 17, 2011, 1:12:12 PM |
Video renderin speed low I tere First my keyboar is defective I do not ave two letters workin . I bout a new computer to render fast my videos on Sweetome3d, bot te speed stills low. I ave a ood macine now Its a I7 2600K, wit 8B of ram And te videos stills take only a litle bit less tan my previous macine, wit was realy slow (core 2 Duo 1.6 wit 2B o mem.) Te instalation is new, clean, only W7 64, firefox and java Wat can be wron wit it? Tks Clovis |
| Posted by Puybaret at Dec 17, 2011, 1:23:40 PM |
Re: Video renderin speed low What quality level do you use? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Clovis at Dec 17, 2011, 3:11:29 PM |
Re: Video renderin speed low Te quality is te same on te two atempts, te second macine sowld be very faster, but its not. Clovis |
| Posted by hansmex at Dec 17, 2011, 3:16:39 PM |
Re: Video renderin speed low What is your file size? How many light sources does your design have? Do you have trees or plants in your design? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Dec 17, 2011, 5:26:23 PM |
Re: Video renderin speed low In the photo creation dialog, what quality do you use? 1, 2, 3 or 4? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Clovis at Dec 17, 2011, 11:34:18 PM |
Re: Video renderin speed low I'm triin to do a ood quality video. I know it will take a lon. Te question is Wy te new macine is not too faster ten te old one, its a realy ood macine, asnd I bout it for tat, to mke te animation faster tan te old one. Te film is 50s lon, wit 1300 frames, quality is 4 and tere is about 12 lit spots onte cealin. te size is 320x240 25 frames. I updatyed te java foa a 64 v ersion and stills slow Clovis |
| Posted by hansmex at Dec 18, 2011, 8:14:20 AM |
Re: Video renderin speed low Clovis, If you want, send me your file, and I will make a test render. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by hansmex at Dec 19, 2011, 7:47:01 AM |
Re: Video renderin speed low Clovis, Before doing a test render on your file, I made a few changes. I decreased the number of lights from 11 to 6, because that would speed up rendering, while still allowing enough light. I did the render on a computer with two cores running Ubuntu 11.10, and 2GB of RAM allotted to SH3D. No other processes were running that consumed a lot of computer time. Check this paragraph in the FAQ to learn how you can allot more memory to SH3D. How can I adjust the memory used by Sweet Home 3D? The initial estimate of SH3D was that the rendering would take +/- 1h30m; the actual rendering took +/- 1h40m.The settings were as I found in your file: Q3 at 320x240 pixels at 25 frames. My guess would be that a rendering at Q4 would take probably 4x as much time. My guess is that a machine with 4 processor cores should do the render in approximately half the time of my machine. You may want to check that - your computer uses all 4 cores - you don't have a program running at the same time that uses a lot of processor time. I have sent the modified file and the movie to your email. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 15, 2026, 4:42:55 AM |
