Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: adding 2 or more imported textures |
| Print at Sep 30, 2026, 10:18:53 AM | |
| Posted by Mep at Dec 26, 2011, 8:58:44 PM |
adding 2 or more imported textures Does anyone know if it is possible to add more than 1 texture per wall? i.e. If I want to make a design on a wall with tiles made of pictures that I import.[email protected] |
| Posted by Puybaret at Dec 26, 2011, 9:19:20 PM |
Re: adding 2 or more imported textures You can add a thin box along the wall and apply a texture on it, or create a special texture as explained in this document. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Dec 26, 2011, 9:58:40 PM |
Re: adding 2 or more imported textures Ami, When you use version 3.4 you can add a Level. Give the wall on the lower level a different colour or texture than the wall on the upper level. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Mep at Dec 27, 2011, 9:08:34 PM |
Re: adding 2 or more imported textures Thank you guys, I will test it out. |
Current timezone is GMT Sep 30, 2026, 10:18:53 AM |
