Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Two floor house |
| Print at Sep 23, 2026, 6:25:13 PM | |
| Posted by cnanu2000 at Dec 27, 2011, 11:21:36 AM |
Two floor house Hi, I succeded to do a "one floor" house. What is the best\easy way to do a two floor house? TIA Nanu |
| Posted by Puybaret at Dec 27, 2011, 11:58:54 AM |
Re: Two floor house What is the best\easy way to do a two floor house? With Plan > Add level menu item. See also the last example added to the gallery, the updated help and the blog article presenting the new features in version 3.4.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by cnanu2000 at Dec 27, 2011, 3:36:39 PM |
Re: Two floor house Thank you, nice version. The place to be buid is a multi level yard. How can be shown the multi level yard before begining to plot\design? TIA Nanu |
| Posted by Puybaret at Dec 27, 2011, 4:01:01 PM |
Re: Two floor house Sweet Home 3D goal is to build multi level houses not multi level gardens. If it's really what you need you should try an other solution, or it will be very tedious to handle. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Dec 27, 2011, 4:45:18 PM |
Re: Two floor house Nanu, The Level function can also be used to do some 'terraforming'. See the attached file for an example. Hans ---------------------------------------- ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by cnanu2000 at Dec 28, 2011, 10:33:06 AM |
Re: Two floor house Nice!!! Thank you! Nanu |
Current timezone is GMT Sep 23, 2026, 6:25:13 PM |
