Print at Sep 24, 2026, 2:39:58 PM
Posted by MischaMolhoek at Jan 16, 2012, 10:16:45 AM
Re: Sweet Home 3D 3.4
Hi there,
First of all a message for pencilart: great work man!.
I just started using your program last night to see how my house would look if a add another level to it :).
I used sweethome3d on osx to make my house as it is right now. worked like a charme!
However, now that want to make some adjustments on My Ubuntu 11.10 (64bit), i found out the latest version with multiple levels, is not running on my Ubuntu machine jet.
I can apt-get install a version for the default repo's which does work, but that is not the most recent version and does not support multiple levels :(
i posted the crash log below, maybe you can see what is wrong with my attemt to run you're super app on Ubuntu :)
tanx in advance,
Mischa
I downloaded the latest ubuntu 64 bit tarball from this site and when i run the ./SweetHome3D, i get the following message:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fdf4b0adc46, pid=2423, tid=140596997953280
# JRE version: 6.0_30-b12
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.5-b03 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libc.so.6+0x34c46] char+0x16
# An error report file with more information is saved as:
# /home/mischa/Downloads/SweetHome3D-3.4/hs_err_pid2423.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted
and this is the contents of hs_err_pid2423.log:
# SIGSEGV (0xb) at pc=0x00007f04e9fd0c46, pid=4525, tid=139659066787584
--------------- T H R E A D ---------------
Current thread (0x000000004019f000): JavaThread "main" [_thread_in_native, id=4528, stack(0x00007f04e900c000,0x00007f04e910d000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x0000000000000008
Registers:
RAX=0x0000000000000013, RBX=0x00000000404319f0, RCX=0x00007f04e2eed92d, RDX=0x0000000000000001
RSP=0x00007f04e910aea8, RBP=0x00007f04e910aed0, RSI=0x0000000000000013, RDI=0x0000000000000000
R8 =0x0000000000000001, R9 =0x0000000000000000, R10=0x00007f04e910ac40, R11=0x00007f04e9fd0c30
R12=0x000000000000010c, R13=0x00000000401fece8, R14=0x000000000000000f, R15=0x00007f04e910b3a8
RIP=0x00007f04e9fd0c46, EFLAGS=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007f04e910aea8)
0x00007f04e910aea8: 00007f04e2e4ad86 00000000401fece8
0x00007f04e910aeb8: 000000000000000f 00007f04e910b3a8
0x00007f04e910aec8: 00000000405ce120 00007f04e910af20
0x00007f04e910aed8: 00007f04e2e4b9a5 00000000009f0001
0x00007f04e910aee8: 000000000000010e 0000000000000000
0x00007f04e910aef8: 00000000401fece8 00007f04e2d063a0
0x00007f04e910af08: 000000000000010c 000000000000010e
0x00007f04e910af18: 00000000405ce120 000000004019f1d0
0x00007f04e910af28: 00007f04e2d064ae 00007f04e300b1f0
0x00007f04e910af38: 00007f04e910afc0 00000000404319f0
0x00007f04e910af48: 00007f04e2d07173 00007f04e5283f58
0x00007f04e910af58: 000001000000000e 0000000000000000
0x00007f04e910af68: 000000004041e9d0 000000004041e9d0
0x00007f04e910af78: 00050019bb70b308 00000000401fece8
0x00007f04e910af88: 0101000000000000 00000000401feaf0
0x00007f04e910af98: 0000000040477020 00007f04e2865100
0x00007f04e910afa8: 0000000000000000 00007f04e910b398
0x00007f04e910afb8: 0000000000000000 00007f04e2657432
0x00007f04e910afc8: 0000000000000000 00007f04e26574b8
0x00007f04e910afd8: 0000000000000001 00007f04e2657408
0x00007f04e910afe8: 000000004041e0f0 00007f04e265795a
0x00007f04e910aff8: 0000000000000020 00007f04e2657963
0x00007f04e910b008: 0000000000000018 00007f04e2657a85
0x00007f04e910b018: 0000000000000000 00007f04e2657c35
0x00007f04e910b028: 0000000000000005 00007f04e2657c37
0x00007f04e910b038: 0000000000000019 00007f04e2657c28
0x00007f04e910b048: 000000000000fff6 00007f04e26579aa
0x00007f04e910b058: 000000000000ffe2 00007f04e2ed9c6b
0x00007f04e910b068: 00000000404df4a0 00007f04e2ed9c87
0x00007f04e910b078: 000000004048fc10 00007f04e2ed9c95
0x00007f04e910b088: 0000000040490510 00007f04e2edb31f
0x00007f04e910b098: 0000000000000001 00007f04e2657b08
Instructions: (pc=0x00007f04e9fd0c46)
0x00007f04e9fd0c26: 66 2e 0f 1f 84 00 00 00 00 00 48 83 ff ff 41 89
0x00007f04e9fd0c36: d0 74 57 83 c6 01 85 f6 7e 50 85 d2 78 4c 89 f0
0x00007f04e9fd0c46: 4c 8b 4f 08 4c 8b 57 18 0f af c2 31 d2 48 98 49
0x00007f04e9fd0c56: f7 f1 4f 8d 0c 49 48 8d 04 52 31 d2 eb 11 0f 1f
Register to memory mapping:
RAX=0x0000000000000013 is an unknown value
RBX=0x00000000404319f0 is an unknown value
RCX=0x00007f04e2eed92d: <offset 0x24a92d> in /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/motif21/libmawt.so at 0x00007f04e2ca3000
RDX=0x0000000000000001 is an unknown value
RSP=0x00007f04e910aea8 is pointing into the stack for thread: 0x000000004019f000
RBP=0x00007f04e910aed0 is pointing into the stack for thread: 0x000000004019f000
RSI=0x0000000000000013 is an unknown value
RDI=0x0000000000000000 is an unknown value
R8 =0x0000000000000001 is an unknown value
R9 =0x0000000000000000 is an unknown value
R10=0x00007f04e910ac40 is pointing into the stack for thread: 0x000000004019f000
R11=0x00007f04e9fd0c30: catgets+0 in /lib/x86_64-linux-gnu/libc.so.6 at 0x00007f04e9f9c000
R12=0x000000000000010c is an unknown value
R13=0x00000000401fece8 is a global jni handle
R14=0x000000000000000f is an unknown value
R15=0x00007f04e910b3a8 is pointing into the stack for thread: 0x000000004019f000
Stack: [0x00007f04e900c000,0x00007f04e910d000], sp=0x00007f04e910aea8, free space=1019k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libmawt.so+0x1a89a5] XmAddProtocolCallback+0x34
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.awt.motif.MWindowPeer.pCreate(Lsun/awt/motif/MComponentPeer;Ljava/lang/String;)V+0
j sun.awt.motif.MWindowPeer.create(Lsun/awt/motif/MComponentPeer;)V+12
j sun.awt.motif.MComponentPeer.init(Ljava/awt/Component;)V+31
j sun.awt.motif.MWindowPeer.init(Ljava/awt/Window;)V+102
j sun.awt.motif.MFramePeer.<init>(Ljava/awt/Frame;)V+159
j sun.awt.motif.MToolkit.createFrame(Ljava/awt/Frame;)Ljava/awt/peer/FramePeer;+5
j java.awt.Frame.addNotify()V+20
j java.awt.Window.addNotify()V+24
j java.awt.Window.show()V+8
j java.awt.Component.show(Z)V+5
j java.awt.Component.setVisible(Z)V+2
j java.awt.Window.setVisible(Z)V+2
j com.eteks.sweethome3d.swing.SwingTools.showSplashScreenWindow(Ljava/net/URL;)V+40
j com.eteks.sweethome3d.SweetHome3D.init([Ljava/lang/String;)V+36
j com.eteks.sweethome3d.SweetHome3D.main([Ljava/lang/String;)V+8
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00000000404db000 JavaThread "AWT-Motif" daemon [_thread_blocked, id=4544, stack(0x00007f04e0861000,0x00007f04e0962000)]
0x000000004057f000 JavaThread "AWT-Shutdown" [_thread_blocked, id=4543, stack(0x00007f04e0962000,0x00007f04e0a63000)]
0x0000000040386000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4542, stack(0x00007f04e136f000,0x00007f04e1470000)]
0x0000000040252000 JavaThread "Timer-0" daemon [_thread_blocked, id=4541, stack(0x00007f04e3231000,0x00007f04e3332000)]
0x000000004022e800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4539, stack(0x00007f04e34ca000,0x00007f04e35cb000)]
0x000000004022b800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=4538, stack(0x00007f04e35cb000,0x00007f04e36cc000)]
0x0000000040228000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=4537, stack(0x00007f04e36cc000,0x00007f04e37cd000)]
0x0000000040226000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4536, stack(0x00007f04e37cd000,0x00007f04e38ce000)]
0x000000004020b000 JavaThread "Finalizer" daemon [_thread_blocked, id=4535, stack(0x00007f04e40c8000,0x00007f04e41c9000)]
0x0000000040203800 JavaThread "Reference Handler" daemon [_thread_blocked, id=4534, stack(0x00007f04e41c9000,0x00007f04e42ca000)]
=>0x000000004019f000 JavaThread "main" [_thread_in_native, id=4528, stack(0x00007f04e900c000,0x00007f04e910d000)]
Other Threads:
0x00000000401fc800 VMThread [stack: 0x00007f04e42ca000,0x00007f04e43cb000] [id=4533]
0x0000000040239000 WatcherThread [stack: 0x00007f04e33c9000,0x00007f04e34ca000] [id=4540]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 18112K, used 4048K [0x00000000eaab0000, 0x00000000ebee0000, 0x0000000100000000)
eden space 15552K, 26% used [0x00000000eaab0000,0x00000000eaea4010,0x00000000eb9e0000)
from space 2560K, 0% used [0x00000000ebc60000,0x00000000ebc60000,0x00000000ebee0000)
to space 2560K, 0% used [0x00000000eb9e0000,0x00000000eb9e0000,0x00000000ebc60000)
PSOldGen total 41408K, used 0K [0x00000000c0000000, 0x00000000c2870000, 0x00000000eaab0000)
object space 41408K, 0% used [0x00000000c0000000,0x00000000c0000000,0x00000000c2870000)
PSPermGen total 21248K, used 9435K [0x00000000bae00000, 0x00000000bc2c0000, 0x00000000c0000000)
object space 21248K, 44% used [0x00000000bae00000,0x00000000bb736e70,0x00000000bc2c0000)
Code Cache [0x00007f04e5276000, 0x00007f04e54e6000, 0x00007f04e8276000)
total_blobs=361 nmethods=27 adapters=288 free_code_cache=49785152 largest_free_block=448
Dynamic libraries:
40000000-40009000 r-xp 00000000 08:01 32769330 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/bin/java
40108000-4010a000 rwxp 00008000 08:01 32769330 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/bin/java
40196000-406f9000 rwxp 00000000 00:00 0 [heap]
bae00000-bc2c0000 rwxp 00000000 00:00 0
bc2c0000-c0000000 rwxp 00000000 00:00 0
c0000000-c2870000 rwxp 00000000 00:00 0
c2870000-eaab0000 rwxp 00000000 00:00 0
eaab0000-ebee0000 rwxp 00000000 00:00 0
ebee0000-100000000 rwxp 00000000 00:00 0
7f04dc000000-7f04dc365000 rwxp 00000000 00:00 0
7f04dc365000-7f04e0000000 ---p 00000000 00:00 0
7f04e0739000-7f04e073a000 r-xs 00000000 08:01 21499213 /var/cache/fontconfig/c05880de57d1f5e948fdfacc138775d9-le64.cache-3
7f04e073a000-7f04e0743000 r-xs 00000000 08:01 21495897 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-le64.cache-3
7f04e0743000-7f04e0745000 r-xs 00000000 08:01 21499151 /var/cache/fontconfig/99e8ed0e538f840c565b6ed5dad60d56-le64.cache-3
7f04e0745000-7f04e0748000 r-xs 00000000 08:01 21499210 /var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-le64.cache-3
7f04e0748000-7f04e074c000 r-xs 00000000 08:01 21499204 /var/cache/fontconfig/2cd17615ca594fa2959ae173292e504c-le64.cache-3
7f04e074c000-7f04e0752000 r-xs 00000000 08:01 21499195 /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-le64.cache-3
7f04e0752000-7f04e0758000 r-xs 00000000 08:01 21499193 /var/cache/fontconfig/515ca1ebc4b18308bea979be5704f9db-le64.cache-3
7f04e0758000-7f04e0761000 r-xs 00000000 08:01 21499192 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-le64.cache-3
7f04e0761000-7f04e078f000 r-xs 00000000 08:01 21499306 /var/cache/fontconfig/365b55f210c0a22e9a19e35191240f32-le64.cache-3
7f04e0861000-7f04e0864000 ---p 00000000 00:00 0
7f04e0864000-7f04e0962000 rwxp 00000000 00:00 0
7f04e0962000-7f04e0965000 ---p 00000000 00:00 0
7f04e0965000-7f04e0a63000 rwxp 00000000 00:00 0
7f04e0a63000-7f04e0a68000 r-xp 00000000 08:01 10098826 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7f04e0a68000-7f04e0c67000 ---p 00005000 08:01 10098826 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7f04e0c67000-7f04e0c68000 r-xp 00004000 08:01 10098826 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7f04e0c68000-7f04e0c69000 rwxp 00005000 08:01 10098826 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7f04e0c69000-7f04e0c72000 r-xp 00000000 08:01 10096965 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7f04e0c72000-7f04e0e72000 ---p 00009000 08:01 10096965 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7f04e0e72000-7f04e0e73000 r-xp 00009000 08:01 10096965 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7f04e0e73000-7f04e0e74000 rwxp 0000a000 08:01 10096965 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7f04e0e74000-7f04e0e7d000 r-xp 00000000 08:01 10098828 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7f04e0e7d000-7f04e107c000 ---p 00009000 08:01 10098828 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7f04e107c000-7f04e107d000 r-xp 00008000 08:01 10098828 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7f04e107d000-7f04e107e000 rwxp 00009000 08:01 10098828 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7f04e109f000-7f04e1118000 r-xp 00000000 08:01 32768602 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libfontmanager.so
7f04e1118000-7f04e1217000 ---p 00079000 08:01 32768602 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libfontmanager.so
7f04e1217000-7f04e122c000 rwxp 00078000 08:01 32768602 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libfontmanager.so
7f04e122c000-7f04e123d000 rwxp 00000000 00:00 0
7f04e123d000-7f04e1269000 r-xp 00000000 08:01 32768615 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libjpeg.so
7f04e1269000-7f04e1369000 ---p 0002c000 08:01 32768615 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libjpeg.so
7f04e1369000-7f04e136f000 rwxp 0002c000 08:01 32768615 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libjpeg.so
7f04e136f000-7f04e1372000 ---p 00000000 00:00 0
7f04e1372000-7f04e1470000 rwxp 00000000 00:00 0
7f04e1470000-7f04e1475000 r-xp 00000000 08:01 10094053 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7f04e1475000-7f04e1674000 ---p 00005000 08:01 10094053 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7f04e1674000-7f04e1675000 r-xp 00004000 08:01 10094053 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7f04e1675000-7f04e1676000 rwxp 00005000 08:01 10094053 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7f04e1676000-7f04e1678000 r-xp 00000000 08:01 10094020 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7f04e1678000-7f04e1877000 ---p 00002000 08:01 10094020 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7f04e1877000-7f04e1878000 r-xp 00001000 08:01 10094020 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7f04e1878000-7f04e1879000 rwxp 00002000 08:01 10094020 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7f04e1879000-7f04e187d000 r-xp 00000000 08:01 45354673 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7f04e187d000-7f04e1a7c000 ---p 00004000 08:01 45354673 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7f04e1a7c000-7f04e1a7d000 r-xp 00003000 08:01 45354673 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7f04e1a7d000-7f04e1a7e000 rwxp 00004000 08:01 45354673 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7f04e1a7e000-7f04e1a99000 r-xp 00000000 08:01 10094057 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7f04e1a99000-7f04e1c98000 ---p 0001b000 08:01 10094057 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7f04e1c98000-7f04e1c99000 r-xp 0001a000 08:01 10094057 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7f04e1c99000-7f04e1c9a000 rwxp 0001b000 08:01 10094057 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7f04e1c9a000-7f04e1cb0000 r-xp 00000000 08:01 10092706 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7f04e1cb0000-7f04e1eaf000 ---p 00016000 08:01 10092706 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7f04e1eaf000-7f04e1eb0000 r-xp 00015000 08:01 10092706 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7f04e1eb0000-7f04e1eb1000 rwxp 00016000 08:01 10092706 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7f04e1eb1000-7f04e1eb4000 rwxp 00000000 00:00 0
7f04e1eb4000-7f04e1ebb000 r-xp 00000000 08:01 10092890 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7f04e1ebb000-7f04e20ba000 ---p 00007000 08:01 10092890 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7f04e20ba000-7f04e20bb000 r-xp 00006000 08:01 10092890 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7f04e20bb000-7f04e20bc000 rwxp 00007000 08:01 10092890 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7f04e20bc000-7f04e20cb000 r-xp 00000000 08:01 10098833 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7f04e20cb000-7f04e22ca000 ---p 0000f000 08:01 10098833 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7f04e22ca000-7f04e22cb000 r-xp 0000e000 08:01 10098833 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7f04e22cb000-7f04e22cc000 rwxp 0000f000 08:01 10098833 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7f04e22cc000-7f04e23ff000 r-xp 00000000 08:01 10094072 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7f04e23ff000-7f04e25ff000 ---p 00133000 08:01 10094072 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7f04e25ff000-7f04e2600000 r-xp 00133000 08:01 10094072 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7f04e2600000-7f04e2604000 rwxp 00134000 08:01 10094072 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7f04e2604000-7f04e2663000 r-xp 00000000 08:01 10094307 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7f04e2663000-7f04e2862000 ---p 0005f000 08:01 10094307 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7f04e2862000-7f04e2863000 r-xp 0005e000 08:01 10094307 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7f04e2863000-7f04e2868000 rwxp 0005f000 08:01 10094307 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7f04e2868000-7f04e2869000 rwxp 00000000 00:00 0
7f04e2869000-7f04e287b000 r-xp 00000000 08:01 10094309 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7f04e287b000-7f04e2a7a000 ---p 00012000 08:01 10094309 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7f04e2a7a000-7f04e2a7b000 r-xp 00011000 08:01 10094309 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7f04e2a7b000-7f04e2a7c000 rwxp 00012000 08:01 10094309 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7f04e2a7c000-7f04e2a81000 r-xp 00000000 08:01 10094311 /usr/lib/libXtst.so.6.1.0
7f04e2a81000-7f04e2c80000 ---p 00005000 08:01 10094311 /usr/lib/libXtst.so.6.1.0
7f04e2c80000-7f04e2c81000 r-xp 00004000 08:01 10094311 /usr/lib/libXtst.so.6.1.0
7f04e2c81000-7f04e2c82000 rwxp 00005000 08:01 10094311 /usr/lib/libXtst.so.6.1.0
7f04e2c82000-7f04e2c83000 r-xs 00000000 08:01 21499202 /var/cache/fontconfig/e7071f4a29fa870f4323321c154eba04-le64.cache-3
7f04e2c83000-7f04e2c93000 r-xs 00000000 08:01 21499189 /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-le64.cache-3
7f04e2c93000-7f04e2ca3000 r-xs 00000000 08:01 21499178 /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-le64.cache-3
7f04e2ca3000-7f04e2f0a000 r-xp 00000000 08:01 32768645 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/motif21/libmawt.so
7f04e2f0a000-7f04e300b000 ---p 00267000 08:01 32768645 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/motif21/libmawt.so
7f04e300b000-7f04e305f000 rwxp 00268000 08:01 32768645 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/motif21/libmawt.so
7f04e305f000-7f04e3062000 rwxp 00000000 00:00 0
7f04e3062000-7f04e30f4000 r-xp 00000000 08:01 32768597 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libawt.so
7f04e30f4000-7f04e31f3000 ---p 00092000 08:01 32768597 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libawt.so
7f04e31f3000-7f04e320d000 rwxp 00091000 08:01 32768597 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libawt.so
7f04e320d000-7f04e3231000 rwxp 00000000 00:00 0
7f04e3231000-7f04e3234000 ---p 00000000 00:00 0
7f04e3234000-7f04e3332000 rwxp 00000000 00:00 0
7f04e3332000-7f04e333b000 r-xs 000c1000 08:01 32768780 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/javaws.jar
7f04e333b000-7f04e333d000 r-xs 0004c000 08:01 32769328 /home/mischa/Downloads/SweetHome3D-3.4/lib/vecmath.jar
7f04e333d000-7f04e334b000 r-xs 00193000 08:01 32769324 /home/mischa/Downloads/SweetHome3D-3.4/lib/j3dutils.jar
7f04e334b000-7f04e3357000 r-xs 002c7000 08:01 32769323 /home/mischa/Downloads/SweetHome3D-3.4/lib/j3dcore.jar
7f04e3357000-7f04e3359000 r-xs 00008000 08:01 32769320 /home/mischa/Downloads/SweetHome3D-3.4/lib/batik-svgpathparser-1.7.jar
7f04e3359000-7f04e3367000 r-xs 000e1000 08:01 32769325 /home/mischa/Downloads/SweetHome3D-3.4/lib/jmf.jar
7f04e3367000-7f04e336e000 r-xs 0004e000 08:01 32769327 /home/mischa/Downloads/SweetHome3D-3.4/lib/sunflow-0.07.3g.jar
7f04e336e000-7f04e3375000 r-xs 0006d000 08:01 32769321 /home/mischa/Downloads/SweetHome3D-3.4/lib/freehep-vectorgraphics-svg-2.1.1.jar
7f04e3375000-7f04e3381000 r-xs 00108000 08:01 32769322 /home/mischa/Downloads/SweetHome3D-3.4/lib/iText-2.1.7.jar
7f04e3381000-7f04e3383000 r-xs 0000b000 08:01 32769314 /home/mischa/Downloads/SweetHome3D-3.4/lib/Loader3DS1_2u.jar
7f04e3383000-7f04e3396000 r-xs 0045a000 08:01 32769313 /home/mischa/Downloads/SweetHome3D-3.4/lib/Help.jar
7f04e3396000-7f04e3398000 r-xs 00076000 08:01 32769316 /home/mischa/Downloads/SweetHome3D-3.4/lib/Textures.jar
7f04e3398000-7f04e339e000 r-xs 00336000 08:01 32769312 /home/mischa/Downloads/SweetHome3D-3.4/lib/Furniture.jar
7f04e339e000-7f04e33c9000 r-xs 00201000 08:01 32769315 /home/mischa/Downloads/SweetHome3D-3.4/lib/SweetHome3D.jar
7f04e33c9000-7f04e33ca000 ---p 00000000 00:00 0
7f04e33ca000-7f04e34ca000 rwxp 00000000 00:00 0
7f04e34ca000-7f04e34cd000 ---p 00000000 00:00 0
7f04e34cd000-7f04e35cb000 rwxp 00000000 00:00 0
7f04e35cb000-7f04e35ce000 ---p 00000000 00:00 0
7f04e35ce000-7f04e36cc000 rwxp 00000000 00:00 0
7f04e36cc000-7f04e36cf000 ---p 00000000 00:00 0
7f04e36cf000-7f04e37cd000 rwxp 00000000 00:00 0
7f04e37cd000-7f04e37d0000 ---p 00000000 00:00 0
7f04e37d0000-7f04e38ce000 rwxp 00000000 00:00 0
7f04e38ce000-7f04e40c8000 r-xp 00000000 08:01 10099855 /usr/lib/locale/locale-archive
7f04e40c8000-7f04e40cb000 ---p 00000000 00:00 0
7f04e40cb000-7f04e41c9000 rwxp 00000000 00:00 0
7f04e41c9000-7f04e41cc000 ---p 00000000 00:00 0
7f04e41cc000-7f04e42ca000 rwxp 00000000 00:00 0
7f04e42ca000-7f04e42cb000 ---p 00000000 00:00 0
7f04e42cb000-7f04e4904000 rwxp 00000000 00:00 0
7f04e4904000-7f04e4aa1000 r-xs 02b8f000 08:01 32768815 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/rt.jar
7f04e4aa1000-7f04e4ac9000 rwxp 00000000 00:00 0
7f04e4ac9000-7f04e4aca000 ---p 00000000 00:00 0
7f04e4aca000-7f04e4bca000 rwxp 00000000 00:00 0
7f04e4bca000-7f04e4bcb000 ---p 00000000 00:00 0
7f04e4bcb000-7f04e4ccb000 rwxp 00000000 00:00 0
7f04e4ccb000-7f04e4ccc000 ---p 00000000 00:00 0
7f04e4ccc000-7f04e4dcc000 rwxp 00000000 00:00 0
7f04e4dcc000-7f04e4dcd000 ---p 00000000 00:00 0
7f04e4dcd000-7f04e4ed8000 rwxp 00000000 00:00 0
7f04e4ed8000-7f04e4ef6000 rwxp 00000000 00:00 0
7f04e4ef6000-7f04e4f0b000 rwxp 00000000 00:00 0
7f04e4f0b000-7f04e504c000 rwxp 00000000 00:00 0
7f04e504c000-7f04e5057000 rwxp 00000000 00:00 0
7f04e5057000-7f04e5075000 rwxp 00000000 00:00 0
7f04e5075000-7f04e508a000 rwxp 00000000 00:00 0
7f04e508a000-7f04e51ca000 rwxp 00000000 00:00 0
7f04e51ca000-7f04e51d5000 rwxp 00000000 00:00 0
7f04e51d5000-7f04e5275000 rwxp 00000000 00:00 0
7f04e5275000-7f04e54e6000 rwxp 00000000 00:00 0
7f04e54e6000-7f04e8276000 rwxp 00000000 00:00 0
7f04e8276000-7f04e8284000 r-xp 00000000 08:01 32768644 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libzip.so
7f04e8284000-7f04e8386000 ---p 0000e000 08:01 32768644 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libzip.so
7f04e8386000-7f04e8389000 rwxp 00010000 08:01 32768644 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libzip.so
7f04e8389000-7f04e838a000 rwxp 00000000 00:00 0
7f04e838a000-7f04e8396000 r-xp 00000000 08:01 45355527 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f04e8396000-7f04e8595000 ---p 0000c000 08:01 45355527 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f04e8595000-7f04e8596000 r-xp 0000b000 08:01 45355527 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f04e8596000-7f04e8597000 rwxp 0000c000 08:01 45355527 /lib/x86_64-linux-gnu/libnss_files-2.13.so
7f04e8597000-7f04e85a1000 r-xp 00000000 08:01 45355535 /lib/x86_64-linux-gnu/libnss_nis-2.13.so
7f04e85a1000-7f04e87a1000 ---p 0000a000 08:01 45355535 /lib/x86_64-linux-gnu/libnss_nis-2.13.so
7f04e87a1000-7f04e87a2000 r-xp 0000a000 08:01 45355535 /lib/x86_64-linux-gnu/libnss_nis-2.13.so
7f04e87a2000-7f04e87a3000 rwxp 0000b000 08:01 45355535 /lib/x86_64-linux-gnu/libnss_nis-2.13.so
7f04e87a3000-7f04e87ab000 r-xp 00000000 08:01 45355517 /lib/x86_64-linux-gnu/libnss_compat-2.13.so
7f04e87ab000-7f04e89aa000 ---p 00008000 08:01 45355517 /lib/x86_64-linux-gnu/libnss_compat-2.13.so
7f04e89aa000-7f04e89ab000 r-xp 00007000 08:01 45355517 /lib/x86_64-linux-gnu/libnss_compat-2.13.so
7f04e89ab000-7f04e89ac000 rwxp 00008000 08:01 45355517 /lib/x86_64-linux-gnu/libnss_compat-2.13.so
7f04e89ac000-7f04e89c3000 r-xp 00000000 08:01 45355521 /lib/x86_64-linux-gnu/libnsl-2.13.so
7f04e89c3000-7f04e8bc2000 ---p 00017000 08:01 45355521 /lib/x86_64-linux-gnu/libnsl-2.13.so
7f04e8bc2000-7f04e8bc3000 r-xp 00016000 08:01 45355521 /lib/x86_64-linux-gnu/libnsl-2.13.so
7f04e8bc3000-7f04e8bc4000 rwxp 00017000 08:01 45355521 /lib/x86_64-linux-gnu/libnsl-2.13.so
7f04e8bc4000-7f04e8bc6000 rwxp 00000000 00:00 0
7f04e8bc6000-7f04e8bef000 r-xp 00000000 08:01 32768610 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libjava.so
7f04e8bef000-7f04e8cee000 ---p 00029000 08:01 32768610 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libjava.so
7f04e8cee000-7f04e8cf5000 rwxp 00028000 08:01 32768610 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libjava.so
7f04e8cf5000-7f04e8d02000 r-xp 00000000 08:01 32768643 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libverify.so
7f04e8d02000-7f04e8e01000 ---p 0000d000 08:01 32768643 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libverify.so
7f04e8e01000-7f04e8e04000 rwxp 0000c000 08:01 32768643 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/libverify.so
7f04e8e04000-7f04e8e0b000 r-xp 00000000 08:01 45350936 /lib/x86_64-linux-gnu/librt-2.13.so
7f04e8e0b000-7f04e900a000 ---p 00007000 08:01 45350936 /lib/x86_64-linux-gnu/librt-2.13.so
7f04e900a000-7f04e900b000 r-xp 00006000 08:01 45350936 /lib/x86_64-linux-gnu/librt-2.13.so
7f04e900b000-7f04e900c000 rwxp 00007000 08:01 45350936 /lib/x86_64-linux-gnu/librt-2.13.so
7f04e900c000-7f04e900f000 ---p 00000000 00:00 0
7f04e900f000-7f04e910d000 rwxp 00000000 00:00 0
7f04e910d000-7f04e9190000 r-xp 00000000 08:01 45355537 /lib/x86_64-linux-gnu/libm-2.13.so
7f04e9190000-7f04e938f000 ---p 00083000 08:01 45355537 /lib/x86_64-linux-gnu/libm-2.13.so
7f04e938f000-7f04e9390000 r-xp 00082000 08:01 45355537 /lib/x86_64-linux-gnu/libm-2.13.so
7f04e9390000-7f04e9391000 rwxp 00083000 08:01 45355537 /lib/x86_64-linux-gnu/libm-2.13.so
7f04e9391000-7f04e9cab000 r-xp 00000000 08:01 32768649 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/server/libjvm.so
7f04e9cab000-7f04e9dad000 ---p 0091a000 08:01 32768649 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/server/libjvm.so
7f04e9dad000-7f04e9f62000 rwxp 0091c000 08:01 32768649 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/server/libjvm.so
7f04e9f62000-7f04e9f9c000 rwxp 00000000 00:00 0
7f04e9f9c000-7f04ea131000 r-xp 00000000 08:01 45355523 /lib/x86_64-linux-gnu/libc-2.13.so
7f04ea131000-7f04ea330000 ---p 00195000 08:01 45355523 /lib/x86_64-linux-gnu/libc-2.13.so
7f04ea330000-7f04ea334000 r-xp 00194000 08:01 45355523 /lib/x86_64-linux-gnu/libc-2.13.so
7f04ea334000-7f04ea335000 rwxp 00198000 08:01 45355523 /lib/x86_64-linux-gnu/libc-2.13.so
7f04ea335000-7f04ea33b000 rwxp 00000000 00:00 0
7f04ea33b000-7f04ea33d000 r-xp 00000000 08:01 45355525 /lib/x86_64-linux-gnu/libdl-2.13.so
7f04ea33d000-7f04ea53d000 ---p 00002000 08:01 45355525 /lib/x86_64-linux-gnu/libdl-2.13.so
7f04ea53d000-7f04ea53e000 r-xp 00002000 08:01 45355525 /lib/x86_64-linux-gnu/libdl-2.13.so
7f04ea53e000-7f04ea53f000 rwxp 00003000 08:01 45355525 /lib/x86_64-linux-gnu/libdl-2.13.so
7f04ea53f000-7f04ea557000 r-xp 00000000 08:01 45355534 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f04ea557000-7f04ea756000 ---p 00018000 08:01 45355534 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f04ea756000-7f04ea757000 r-xp 00017000 08:01 45355534 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f04ea757000-7f04ea758000 rwxp 00018000 08:01 45355534 /lib/x86_64-linux-gnu/libpthread-2.13.so
7f04ea758000-7f04ea75c000 rwxp 00000000 00:00 0
7f04ea75c000-7f04ea77d000 r-xp 00000000 08:01 45355532 /lib/x86_64-linux-gnu/ld-2.13.so
7f04ea77d000-7f04ea782000 r-xs 00000000 08:01 21499201 /var/cache/fontconfig/6eb3985aa4124903f6ff08ba781cd364-le64.cache-3
7f04ea782000-7f04ea783000 r-xs 00000000 08:01 21499200 /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-le64.cache-3
7f04ea783000-7f04ea784000 r-xs 00000000 08:01 21499198 /var/cache/fontconfig/0d8c3b2ac0904cb8a57a757ad11a4a08-le64.cache-3
7f04ea784000-7f04ea785000 r-xs 00000000 08:01 21499197 /var/cache/fontconfig/6a53c69dea097a2d716e069445527da8-le64.cache-3
7f04ea785000-7f04ea788000 r-xs 00000000 08:01 21499188 /var/cache/fontconfig/d60319d88cac85ba9e1a07bd06cfbb8c-le64.cache-3
7f04ea788000-7f04ea78a000 r-xs 00000000 08:01 21499182 /var/cache/fontconfig/ddd4086aec35a5275babba44bb759c3c-le64.cache-3
7f04ea78a000-7f04ea78b000 r-xs 00000000 08:01 21499180 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-le64.cache-3
7f04ea78b000-7f04ea795000 rwxp 00000000 00:00 0
7f04ea795000-7f04ea84b000 rwxp 00000000 00:00 0
7f04ea84b000-7f04ea84e000 rwxp 00000000 00:00 0
7f04ea84e000-7f04ea855000 r-xp 00000000 08:01 32768594 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/jli/libjli.so
7f04ea855000-7f04ea956000 ---p 00007000 08:01 32768594 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/jli/libjli.so
7f04ea956000-7f04ea958000 rwxp 00008000 08:01 32768594 /home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/jli/libjli.so
7f04ea958000-7f04ea959000 rwxp 00000000 00:00 0
7f04ea959000-7f04ea961000 r-xs 00000000 08:01 21498299 /var/cache/fontconfig/153bb866d4d26e7cd19eee2129f8d8d2-le64.cache-3
7f04ea961000-7f04ea96c000 r-xs 00000000 08:01 21499169 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-le64.cache-3
7f04ea96c000-7f04ea970000 r-xs 00000000 08:01 21498293 /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-le64.cache-3
7f04ea970000-7f04ea978000 rwxs 00000000 08:01 42336272 /tmp/hsperfdata_mischa/4525
7f04ea978000-7f04ea979000 rwxp 00000000 00:00 0
7f04ea979000-7f04ea97a000 r-xp 00000000 00:00 0
7f04ea97a000-7f04ea97c000 rwxp 00000000 00:00 0
7f04ea97c000-7f04ea97d000 r-xp 00020000 08:01 45355532 /lib/x86_64-linux-gnu/ld-2.13.so
7f04ea97d000-7f04ea97f000 rwxp 00021000 08:01 45355532 /lib/x86_64-linux-gnu/ld-2.13.so
7fffb16f9000-7fffb171b000 rwxp 00000000 00:00 0 [stack]
7fffb17ff000-7fffb1800000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
VM Arguments:
jvm_args: -Xmx1024m -Djava.library.path=./lib
java_command: com.eteks.sweethome3d.SweetHome3D -open
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/home/mischa/bin:/home/mischa/bin:/home/mischa/.gem/ruby/1.8/bin:/var/lib/gems/1.8/bin/:/home/mischa/.gem/ruby/1.8/bin/:/home/solidcode/elara/optiqueue/bin:/opt/pdfraster/:/home/mischa/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/mischa/.rvm/bin
USERNAME=mischa
LD_LIBRARY_PATH=/home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64/server:/home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/lib/amd64:/home/mischa/Downloads/SweetHome3D-3.4/jre1.6.0_30/../lib/amd64:/opt/firefox_2.0.0.14
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x85f7d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x85f7d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x70e3e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x70e3e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x70e3e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x70e3e0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x711210], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x710e10], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x710e10], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x710e10], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x710e10], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:wheezy/sid
uname:Linux 3.0.0-14-generic #23-Ubuntu SMP Mon Nov 21 20:28:43 UTC 2011 x86_64
libc:glibc 2.13 NPTL 2.13
rlimit: STACK 8192k, CORE 0k, NPROC 30885, NOFILE 4096, AS infinity
load average:0.25 0.53 0.46
/proc/meminfo:
MemTotal: 3969128 kB
MemFree: 1288984 kB
Buffers: 190912 kB
Cached: 1356984 kB
SwapCached: 0 kB
Active: 1415728 kB
Inactive: 979376 kB
Active(anon): 908524 kB
Inactive(anon): 235692 kB
Active(file): 507204 kB
Inactive(file): 743684 kB
Unevictable: 68 kB
Mlocked: 68 kB
SwapTotal: 9766908 kB
SwapFree: 9766908 kB
Dirty: 156840 kB
Writeback: 0 kB
AnonPages: 847480 kB
Mapped: 222668 kB
Shmem: 297012 kB
Slab: 157496 kB
SReclaimable: 135472 kB
SUnreclaim: 22024 kB
KernelStack: 3184 kB
PageTables: 30464 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 11751472 kB
Committed_AS: 3547576 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 579072 kB
VmallocChunk: 34359154788 kB
HardwareCorrupted: 0 kB
AnonHugePages: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
DirectMap4k: 63488 kB
DirectMap2M: 4046848 kB
CPU:total 4 (2 cores per cpu, 2 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
/proc/cpuinfo:
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 42
model name : Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
stepping : 7
cpu MHz : 1600.000
cache size : 3072 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt xsave avx lahf_lm arat epb xsaveopt pln pts dts tpr_shadow vnmi flexpriority ept vpid
bogomips : 6185.43
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 42
stepping : 7
cpu MHz : 1600.000
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 6185.65
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 42
stepping : 7
cpu MHz : 2400.000
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 6185.66
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 42
stepping : 7
cpu MHz : 3100.000
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 6185.66
clflush size : 64
power management:
Memory: 4k page, physical 3969128k(1288984k free), swap 9766908k(9766908k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (20.5-b03) for linux-amd64 JRE (1.6.0_30-b12), built on Nov 10 2011 01:14:04 by "java_re" with gcc 3.2.2 (SuSE Linux)
time: Mon Jan 16 09:30:15 2012
elapsed time: 0 seconds
Posted by hansmex at Jan 16, 2012, 10:38:00 AM
Mischa,
To correctly install SH3D v3.4 on your Ubuntu 11.10 machine, proceed as follows:
- uninstall all versions of Java on your PC
- download the 64 bits version of SH3D
- unzip the file in the directory where you want the program to be (no need to use apt-get or something similar)
- go to the directory where you unpacked SH3D and double-click the file SweetHome3D (818 bytes) to launch the program
That's all. It works fine on my Ubuntu 11.10 64-bits PC.
