Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: merge many files in one? |
| Print at Oct 4, 2026, 9:06:39 PM | |
| Posted by krunchyfrog at Jan 28, 2012, 1:29:01 PM |
merge many files in one? Hello, Before version 3.4 I simply did a few files for the different floors of my house and the future extension of it. Is there a way to merge them all together now? It's basically 3 files: the original first floor that is about 4ft above ground, the garage, at ground level, and the second floor that will cover the two first file's widths together. I hoped simply copy and pasting would suffice, but no go. Thanks K |
| Posted by hansmex at Jan 28, 2012, 2:03:53 PM |
Re: merge many files in one? Yes, you can do that. It's a simple Copy & Paste action. 1 - Open a target file where all floors will be combined 2 - Use Plan --> Add level to make as many levels as needed. 3 - Open your first source file and select everything with CTRL-A, then copy it with CTRL-C 4 - Switch to your target file, select the correct level and paste everything with CTRL-V 5 - Repeat step 3 and 4 for the other files/floors. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by krunchyfrog at Jan 28, 2012, 2:45:22 PM |
Re: merge many files in one? thanks! didn`t try ctrl-a, I simply tried selection and that wasnt working. I noticed however that a few furnitures didn`t take the import correctly, like a few werent in the right height (computer hanging in thin air for example) and others had lost their textures. But thats ok, I was about to redo a few of them anyway ;) |
| Posted by Kytrix at Feb 3, 2012, 6:27:23 PM |
Re: merge many files in one? Hello, I am aslo using the Copy/Paste tips to merge many files, but how to do rotate one whole plan ? (I try Ctrl+A then group then rotate, but the base plan is not rotated :/ ) I also try with différent compas, but it doesn't work too. |
| Posted by hansmex at Feb 3, 2012, 7:15:09 PM |
Re: merge many files in one? Download the plug-in tutorial (PDF). Install and use the RotatePlan plug-in. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Kytrix at Feb 3, 2012, 8:07:47 PM |
Re: merge many files in one? Thank you ! It works well :) |
Current timezone is GMT Oct 4, 2026, 9:06:39 PM |
