Print at Oct 3, 2026, 2:27:04 AM
Posted by lfp at Feb 5, 2012, 7:37:31 PM
confused   Ground levels
I'm newbie but I really appreciate this program is helping me a lot to plan my new house.
I could manage to make the plan based on an existing one, but I just found a problem that would like to put it here.
The house will have only a ground level (no 1st floor), but the ground has two levels the back of the terrain/ground is higher 1,20mts and the front is 0mts.
How can I do this ? confused
Many thanks
Posted by hansmex at Feb 5, 2012, 8:08:13 PM
Re: Ground levels
Leonel,
Since version 3.4 you can use Plan -> Add level.
This allows you to design one part of the house at level +0 cms, and one part at level +120 cms.
You can then surround the house by triangles and boxes that mimic the sloping terrain.
See the example I made.
Attachment sloping terrain.sh3d (17410 bytes) (Download count: 831725)
Posted by lfp at Feb 5, 2012, 8:31:55 PM
Re: Ground levels
Hi Hans,
Thank you for your kind answer.
I think that's all I need, I will give a try based on your example.
Thanks
