Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Applying some or all properties of one home furniture object to one or more other home furniture objects |
| Print at Oct 2, 2026, 12:10:12 AM | |
| Posted by rohitverma at Feb 15, 2012, 10:21:15 AM |
Applying some or all properties of one home furniture object to one or more other home furniture objects Hi, There should be a wizard to apply properties of one home furniture object to one or more other home furniture objects.. properties can include ; x y coordinates, width, height, depth, color, texture etc... e.g; for a newly added home furniture object..instead of new user typing all the properties he can select property of other home furniture object and apply properties (by clicking check boxes in a wizard instead of typing numbers).. similarly user can apply one or more properties of one home furniture object to more than one other home furniture objects by doing so in a wizard wizard can have three sections 1) for selecting source home furniture objects 2) for selecting check boxes of source furniture object properties (with editable values..so that user can change one or two values if he wants to ) to be applied to target furniture objects 3) target home furniture objects with check boxes for selection apply, cancel button cheers |
| Posted by rohitverma at Feb 15, 2012, 11:58:37 AM |
Re: Applying some or all properties of one home furniture object to one or more other home furniture objects Somebody please reply if this sounds good or another alternative exists.. thanks in advance |
| Posted by hansmex at Feb 15, 2012, 1:02:59 PM |
Re: Applying some or all properties of one home furniture object to one or more other home furniture objects There is a plug-in called DuplicateStyle that does part of what you want. See the plug-in tutorial (PDF). Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by rohitverma at Feb 17, 2012, 3:03:09 AM |
Re: Applying some or all properties of one home furniture object to one or more other home furniture objects thanks hans |
Current timezone is GMT Oct 2, 2026, 12:10:12 AM |
