Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to keep instalations = |
| Print at Sep 30, 2026, 3:53:43 PM | |
| Posted by Clovis at Feb 28, 2012, 6:38:33 PM |
How to keep instalations = Hi there. I use sw3d with 2 different computers and on each one I have some furniture but There are some diferences I'd like to keep both machines with the same configurations and same furnitures, templates, etc. How Can I do that? Both machines are runnig W7 Tks Clovis |
| Posted by hansmex at Feb 28, 2012, 7:15:45 PM |
Re: How to keep instalations = Clovis, Did you try using the function Furniture -> Export imported furniture to SH3F ? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Feb 28, 2012, 8:15:36 PM |
Re: How to keep instalations = The easiest is to copy the content of the content of the directory C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\furniture from one computer to the other. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Clovis at Feb 29, 2012, 5:14:15 PM |
Re: How to keep instalations = Doing the copies all the furnitue will be imported, OK! And about the textures for cealings and floors? wuere are the files to be copied? TKS Clovis |
| Posted by Puybaret at Feb 29, 2012, 7:10:21 PM |
Re: How to keep instalations = Sorry I should have wrote to copy all the content of: C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D (the work subfolder which might might be quite big is not necessary). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Clovis at Mar 2, 2012, 8:29:06 PM |
Re: How to keep instalations = Puybaret Hi I toke a look at mi machine and did not find this sub/folder On my machie I Have the fololoing folder: C:\Users\Clovis\Application Data\eTeks\Sweet Home 3D and inside this folder has : furniture (folder) recovery (folder) works (folder) and a lot of archives caled furniture-3-xxxxxxxxxxxx.pref On APP data there is not a eTeks folder coping the finded archives will resolve my problem? Thanks again Clovis |
| Posted by Puybaret at Mar 2, 2012, 8:53:25 PM |
Re: How to keep instalations = If there isn't a C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D folder in your destination computer, open Preferences in Sweet Home 3D on that computer and change any value to create it. Then copy all the content of the Sweet Home 3D of the original computer to the destination computer, excluding the work sub folder but including the *.pref files. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 3:53:43 PM |
