Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D view problems |
| Print at Oct 3, 2026, 10:48:18 PM | |
| Posted by duskodalm at Mar 1, 2012, 1:25:01 PM |
3D view problems I can't see upper level in my house with 3D view. Please help me...thank's... |
| Posted by Puybaret at Mar 1, 2012, 1:36:18 PM |
Re: 3D view problems When you manage multiple levels, you should take care of which option is selected between the menu items 3D view > Display all levels and 3D view > Display selected level. If the second one is selected, only the level selected in plan and levels below it will be viewed in the 3D view. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by duskodalm at Mar 1, 2012, 1:54:29 PM |
Re: 3D view problems Ok,thank's...but I want to see second level with 3D view inside.Is it possible? |
| Posted by Puybaret at Mar 1, 2012, 2:10:26 PM |
Re: 3D view problems Select second level tab or 3D view > Display all levels. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by duskodalm at Mar 1, 2012, 2:55:55 PM |
Re: 3D view problems Ok,I did it,but i still have aerial view.Is it possible to visit the upper level and look like the lower level,get inside the building as a visitor? I'm sorry if I'm boring, thanks to every kind of help... :-) |
| Posted by Puybaret at Mar 1, 2012, 4:02:15 PM |
Re: 3D view problems Change level using the elevation indicator drawn in the back of the visitor in the plan. See also help about 3D view modification for more help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by duskodalm at Mar 1, 2012, 5:14:55 PM |
Re: 3D view problems Thank's...I changed... In this video http://www.youtube.com/watch?v=EssRoCuwu_o&feature=related, the visitor goes through the second level. How? |
Current timezone is GMT Oct 3, 2026, 10:48:18 PM |
