Print at Sep 30, 2026, 11:13:02 PM
Posted by choe at Mar 9, 2012, 10:25:46 PM
sad   swh3d stops open production file
All of a sudden swh3D refuses to open a file I'm working with. I'm, pretty desperate as I'm already running late with this project.
I enclose the error message I get when launching it app from the terminal
any help appreciated.
Thanks
_______________
Error message
chroe@linuXin:~/Programme/SweetHome3D-3.4$ ./SweetHome3D
Exception occurred during event dispatching:
java.lang.IllegalArgumentException: moveColumn() - Index out of range
at javax.swing.table.DefaultTableColumnModel.moveColumn(Unknown Source)
at com.eteks.sweethome3d.swing.FurnitureTable$FurnitureTableColumnModel.updateModelColumns(Unknown Source)
at com.eteks.sweethome3d.swing.FurnitureTable$FurnitureTableColumnModel.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.FurnitureTable.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createFurnitureView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.FurnitureController.getView(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.createCatalogFurniturePane(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.createMainPane(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$2.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$29.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.eteks.sweethome3d.swing.ThreadedTaskPanel.setTaskRunning(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1$1.run(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Posted by Puybaret at Mar 9, 2012, 10:37:17 PM
Re: swh3d stops open production file
Please send me your file. I'll try to fix it.
Posted by likaroli at Oct 22, 2012, 1:08:29 AM
hey i cant open my file can somebody help me :(
Posted by Puybaret at Oct 22, 2012, 8:59:46 AM
likaroli, thanks for sending your file. I fixed the problem in your file and sent you the correct file.
The issue was different from choe's one, and it came from a DAE file you imported with accentuated letters.
I didn't find how to reproduce the bug but found a way to avoid it in Sweet Home 3D.
Until next version is released, please remove accentuated letters from 3D models files before importing them.
Posted by Puybaret at Oct 26, 2012, 12:29:30 AM
likaroli, the bug you encountered is fixed in the version 3.7 I just released.
