Print at Oct 7, 2026, 6:47:39 AM
Posted by krneki at Mar 13, 2012, 1:59:31 PM
verified digital signature
Hi. I was using online version for two mounths fine but now suddenly my digital signatur is not verified. What happend? Why was he working before and not now? Thanks for answers
Posted by Puybaret at Mar 13, 2012, 5:21:06 PM
Re: verified digital signature
As far as I can remember, self signed certificates are valid only during two months. An expired certificate won't prevent the applet from running, but it looks like the user will be warned.
You should create a new certificate and sign your Jar files with it. Miserably, that will oblige your users to download the Jar files again, but as far as I know, this is the only solution with self signed certificates.
Posted by krneki at Mar 14, 2012, 1:12:05 PM
Ok I tried building applet on several different servers and making several different digital signatures on other mashines and now applet doesnt work nowhere. For every signature and mashine the applet does not work. What is the problem?
Posted by Puybaret at Mar 14, 2012, 1:37:13 PM
If you don't report any error, it won't be possible to help you! But if it used to work, there's no reason it wouldn't work again.
By the way, explaining the goal of your applet to the community would be nice. Note also that if you want to deploy it on a public web server, the GNU GPL will require you to distribute your modification under the same license including its source code.
