Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: problem with import and texture problem |
| Print at Sep 29, 2026, 2:49:32 AM | |
| Posted by Carina2011 at Mar 29, 2012, 3:38:04 PM |
problem with import and texture problem i have the problem when i import a texture( so they must look) and so it looks when i import this I can select the file from the importer but what the problem is that the model textures are not loaded anyway ... Now my question ... How do I get the point that the textures to be loaded when importing into SweetHome3D? I can select the file from the importer but what the problem is that the model textures are not loaded anyway . |
| Posted by hansmex at Mar 29, 2012, 4:12:03 PM |
Re: problem with import and texture problem Wat kind of file is it ? Dae, obj, 3ds, zip? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Carina2011 at Mar 29, 2012, 4:17:39 PM |
Re: problem with import and texture problem Both in obj and 3ds |
| Posted by hansmex at Mar 29, 2012, 4:39:44 PM |
Re: problem with import and texture problem If both the 3DS and the OBJ file show the model without its textures, than most probably the models aren't included in the download. There are a few sites that offer free models without textures. If you downloaded an OBJ file, check if there is also a MTL file for the textures. If it's a ZIP file, check if within the ZIP file there's an OBJ and an MTL file. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Carina2011 at Mar 29, 2012, 5:08:01 PM |
Re: problem with import and texture problem i have make the model. i have check al both mtl etc. but it dont work ;( |
| Posted by Puybaret at Mar 29, 2012, 7:15:14 PM |
Re: problem with import and texture problem You should check how you exported your model from the modeler you use. First the faces are inverted, something you can fix with the check box at the second step of the import furniture wizard. Then, maybe you didn't generate texture coordinates or files have incorrect names (avoid spaces). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 2:49:32 AM |
