Print at Sep 30, 2026, 9:38:36 AM
Posted by txwikinger at Apr 8, 2012, 4:17:39 AM
How to select all objects in all levels
I have created a multi-level structure and would like to move all objects that are part of it. Hoow can I do this?
Thanks
Posted by Puybaret at Apr 8, 2012, 11:40:50 AM
Re: How to select all objects in all levels
You can select all the lines in the furniture list at bottom left, and copy paste it if needed.
Posted by txwikinger at Apr 11, 2012, 7:38:28 PM
Yes, but I need to select all objects, not only furniture, i.e. also the walls and rooms from the other levels
Posted by Puybaret at Apr 11, 2012, 8:00:23 PM
It's not possible at this time. But I wonder why you need such a feature.
Posted by cnanu2000 at Apr 12, 2012, 8:11:51 AM
It works for me.
I can select all or part of any object\s and copy paste to othe level floor.
I used it to copy exterior walls from one floor to other.
HTH
Nanu
Posted by Puybaret at Apr 12, 2012, 6:11:54 PM
cnanu2000, I guess txwikinger wants to select all objects in all levels at the same time. wink
I wouldn't mind to program this feature but as it will need some programming to show to the user that all levels are selected, I prefer to have some interesting use case before starting.
Posted by Jobil at Jul 15, 2012, 10:29:22 PM
I have the same need. My use case is to design also the outdoors. So I would like to move the entire house in the building plot.
Thank you in advance
Jobil
Posted by cleveroff at Dec 21, 2012, 1:16:58 AM
I have the same need too. I have two seperated plans, one with house, another with bath-house. Both plans have many levels. Now I want to merge these plans in one file. Help!
Posted by cleveroff at Dec 22, 2012, 12:22:46 AM
Probably I understood, that it is impossible. Because the dimensions of levels in both plans are too different.
